Hemi Cross Ram
#2697993
09/16/19 10:07 AM
09/16/19 10:07 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Does anybody have any feed back on Mopar Performance Cross Ram Intake Manifold MOPP5007534? I have a 605” pump gas hemi with a dominator. Wanting to change the look to more period correct manifold but I don’t want to lose to much performance if any.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Hemi Cross Ram
[Re: 65 Hemi]
#2698019
09/16/19 11:14 AM
09/16/19 11:14 AM
Posts: 2,676 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have a 65 Dodge like you. And I have a single 4 on it like you. And you are correct. It looks totally wrong. I assume the new crossram would work much better than the original because of the larger and better shaped ports. I have a ported one of those that I would sell if you want it. And I have some carbs. You are right. It would look much better. Single 4 on a hemi is just totally wrong. Especially on a 65.
2011 Drag Pak Challenger
Re: Hemi Cross Ram
[Re: old_racer]
#2698031
09/16/19 11:38 AM
09/16/19 11:38 AM
Posts: 9,869 MI, usa
dvw
MI, usa
two of the guys on our circuit run them on hemi's , both run original holleys, one's guy has a 572 other has 540 both run 9.50s to 9.60s Jake 68 has run one on his brothers 64 Belvedere in the 8.80s Doug
Re: Hemi Cross Ram
[Re: 65 Hemi]
#2698045
09/16/19 12:14 PM
09/16/19 12:14 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
I know of several guys that bought those intakes and couldn't make them work well I've owned, race and driven a stock 1968 aluminum SS cross ram intake with a set of 1968 carbs that John Bauman had done for that car, that set up worked very well Me thinks the cast 2x4 cross ram intake from Ray Barton would be a much better choice, if he still has any of them
Re: Hemi Cross Ram
[Re: rickseeman]
#2698181
09/16/19 07:00 PM
09/16/19 07:00 PM
Cab_Burge
I've wonder about the other supplier of OEM looking M.W and Hemi SS looking Repo crossram intakes, any one on here used one of the Hemi intakes
Re: Hemi Cross Ram
[Re: Rhinodart]
#2700170
09/23/19 03:57 PM
09/23/19 03:57 PM
rickseeman
Stuttgart, Arkansas
Those are nice repops of the originals. I don't know if they have any in stock. I tried to get an air cleaner from them a few months ago but they were out. I think he's wanting the Mopar Performance crossram with the bigger ports.
