speedo gear ? #2697909
09/15/19 10:43 PM
09/15/19 10:43 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
what tooth count gear do i need for 3.55 gears with 235 x 60 x 15" tire.
thank you !
Re: speedo gear ? [Re: calrobb2000] #2697913
09/15/19 11:06 PM
09/15/19 11:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
from the tech archives. http://www.moparts.org/Tech/tech/pages/speedo.html. you can find the tire diameter at tirerack.com
Re: speedo gear ? [Re: calrobb2000] #2697949
09/16/19 06:39 AM
09/16/19 06:39 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There are at least three different style speedometer gears that do not interchange.
What are you driving? Because that chart in the archives only covers one of them
Re: speedo gear ? [Re: calrobb2000] #2698065
09/16/19 12:57 PM
09/16/19 12:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That tire size usually takes a speedo pinion of the same number as the axle ratio. IOW, 3.55 could use either a 35 or 36-tooth pinion.
