Overheating Problem
#269743
03/28/09 06:36 PM
03/28/09 06:36 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
I got a 91 daytona 2.5L that is overheating. The coolant is full and i cant see any leaks but the guage will show it overheating within about 10 mins of driving. It will drop when the blower fan is turned on high. The rad fan doesnt seem to want to come on even when it is on defrost and on high. If i turn the fan manually it will kick in. Does this sound like it will just be a fan or could the head gasket be bad too? Thanks
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
Re: Overheating Problem
[Re: AARCONV]
#269746
03/28/09 06:59 PM
03/28/09 06:59 PM
sreinheimer
Winnipeg, MB
The oil doesnt look like it haz coolant in it nor does it taste like it either. The only other thing is the resevoir bottle is overfull. The fan relay could cause it too work when spun by hand?
05 Dodge Magnum R/T
[Re: NITROUSN]
#269748
03/28/09 07:03 PM
03/28/09 07:03 PM
sreinheimer
Winnipeg, MB
well it was overfilled by a friend of mine
05 Dodge Magnum R/T
[Re: NITROUSN]
#269750
03/28/09 07:57 PM
03/28/09 07:57 PM
sreinheimer
Winnipeg, MB
An overfull resevoir shouldn't cause the overheating problem should it? How else can i check to see if its a head gasket problem or not? Also it has just started to warm up here in Winnipeg and it just started doing this 2 days ago
05 Dodge Magnum R/T
[Re: stumpy]
#269752
03/28/09 08:12 PM
03/28/09 08:12 PM
sreinheimer
Winnipeg, MB
Ok im thinking the motor for the fan might be seizing up and i told my friend that she shouldnt drive it and its only about 0 degrees celsius here right now
05 Dodge Magnum R/T
[Re: sreinheimer]
#269755
03/28/09 09:06 PM
03/28/09 09:06 PM
RapidRobert
Alright, if the fan being on takes care of things then we just need to get it to come on either by testing the stat that sends fire to the relay the relay itself or the related wiring to & from. You could wire it manually if the relay and stat are OK but if she is not a dedicated car guy then to get it back to kicking on automatically at the right temp the way it originally worked would be the best plan other wise if she doesn't catch it in time & switch it on it could be disaster.
[Re: sreinheimer]
#269757
03/28/09 09:10 PM
03/28/09 09:10 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
No it wont cause overheating. If it is overfilling on its own its a very good sign of a failed head gasket. At this cold of an ambient temperature the fan should not be needed at all.
[Re: AARCONV]
#269758
03/28/09 09:24 PM
03/28/09 09:24 PM
sreinheimer
Winnipeg, MB
So if i understand correctly i should check my powers and grounds at the fan and if they are good then the motor would be no good?
05 Dodge Magnum R/T
[Re: AARCONV]
#269759
03/28/09 11:23 PM
03/28/09 11:23 PM
sreinheimer
Winnipeg, MB
ok i had her check a few things. The fan will turn on when the a/c is on but it will only stay on for a few seconds and turn off and then turn on again then off. If the blower is on defrost the fan will do the same thing. is this normal? Also she says that it looks like there are a few bubbles in the resevoir too. So is this sounding like a head gasket?
05 Dodge Magnum R/T
