solvent tank, what solvent to use? #2696765
09/11/19 11:38 PM
09/11/19 11:38 PM
RapidRobert Offline OP
30 gallon capacity. It's cleaned & ready to be replaced. what should I get? thank you for your time.
Re: solvent tank, what solvent to use? [Re: RapidRobert] #2696770
09/11/19 11:46 PM
09/11/19 11:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I used to get my solvent from tractor supply but got tired of the stink. I switched to kerosene with zero complaints and a bonus is I use kerosene to burn several times a year so I can change out more often. I have a nice link saved from Yellowbullet on adding an oil filter to filter it if you are interested
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: solvent tank, what solvent to use? [Re: RapidRobert] #2696772
09/11/19 11:54 PM
09/11/19 11:54 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I only buy stoddard solvent, naptha is the same hazard class but it is not the same stuff. For me if I dont use gloves, stoddard solvent will make my hands tingle, naptha will not. It is a very standard industrial solvent. You can also look for PD680 type 2, it is an effective degreaser.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: solvent tank, what solvent to use? [Re: astjp2] #2696794
09/12/19 05:42 AM
09/12/19 05:42 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
We use mineral spirits.
Re: solvent tank, what solvent to use? [Re: RapidRobert] #2696822
09/12/19 09:29 AM
09/12/19 09:29 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I buy mine direct from the machine shop I use. Not sure what brand but been doing this for 20 yrs.
Ok
Re: solvent tank, what solvent to use? [Re: cudatom] #2696834
09/12/19 10:03 AM
09/12/19 10:03 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
ALWAYS ..wear rubber gloves, my doctor says the skin absorbs it and to your organs in minutes
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: solvent tank, what solvent to use? [Re: cudatom] #2696836
09/12/19 10:06 AM
09/12/19 10:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: solvent tank, what solvent to use? [Re: Al_Alguire] #2696846
09/12/19 10:39 AM
09/12/19 10:39 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mineral spirits here too and gloves.
Re: solvent tank, what solvent to use? [Re: bigdad] #2696856
09/12/19 11:21 AM
09/12/19 11:21 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I'm with you
2011 Drag Pak Challenger
Re: solvent tank, what solvent to use? [Re: pittsburghracer] #2696867
09/12/19 11:57 AM
09/12/19 11:57 AM
moparx Offline
moparx  Offline
i'm interested in the filter link if you could.
TIA ! up
beer
Re: solvent tank, what solvent to use? [Re: moparx] #2696869
09/12/19 12:14 PM
09/12/19 12:14 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
TIA ! up
beer
iagree
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: solvent tank, what solvent to use? [Re: DynoDave] #2696873
09/12/19 12:25 PM
09/12/19 12:25 PM
I use Shell solvent 360 or Stoddard, 5 to 10 gallons only up
Re: solvent tank, what solvent to use? [Re: moparx] #2696905
09/12/19 02:26 PM
09/12/19 02:26 PM
PA.
"Little"John
"Little"John
PA.
TIA ! up
beer
Wow I was starting to think I lost the link when my old computer bit the dust. I bought everything to do this but when I cleaned my tank last year I ended up fixing the pump that was in the tank new. One of these days I will finish the job. I hope Photobucket didn't mess up the guys pictures to bad.
https://www.yellowbullet.com/forum/showthread.php?t=1083210&highlight=parts+washer+pump
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: solvent tank, what solvent to use? [Re: pittsburghracer] #2696946
09/12/19 05:05 PM
09/12/19 05:05 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use mineral spirits in the big tank. When it gets to diluted and dirty, I put it in a separate tank that I use to pre-clean the really nasty dirty stuff to extend the life of the new, clean mineral spirits in the main tank. If performs well, no complaints. I use simple green and water in the ultrasonic cleaner. I always wear gloves before dipping my paws int any of this stuff.
Now, since mineral spirits has gotten so expensive, Sometime I pour a little bit of gas in a bucket and clean stuff outside.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: solvent tank, what solvent to use? [Re: Hemi_Joel] #2696951
09/12/19 05:37 PM
09/12/19 05:37 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Are you just using it to degrease or do you want to remove some paint or other build up? There's spray gun cleaner that does it all.
Re: solvent tank, what solvent to use? [Re: A/MP] #2696972
09/12/19 06:12 PM
09/12/19 06:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You want a well ventilated shop for that stuff - and pitch the rags, etc outside afterwards. just opening the can will have the odor lingering for days !!
Re: solvent tank, what solvent to use? [Re: Stanton] #2696979
09/12/19 06:26 PM
09/12/19 06:26 PM
PA.
"Little"John
"Little"John
PA.
I have a wall mount invented natural gas heater in my shop. Fumes from spray cans or strong tank cleaners are burnt by my heater and give off terrible fumes. Kerosene in my parts tank have helped with this
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: solvent tank, what solvent to use? [Re: pittsburghracer] #2697073
09/13/19 03:44 AM
09/13/19 03:44 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Solvent fumes linger about 12-18" from the floor. That's why your combustion air intake needs to be above that. Same way with a soak tank, your sides should be at least 12" taller that your solvent level. Doing so keeps the fumes from flowing over to the floor and keeps the working strength longer. For tight shops, a 30 gallon drum placed inside a 55 gallon drum gives you a safer and effective soaker. Any fumes that roll over the edge of the 30 go down to the 55. Get a 55 gallon drum dolly and you can easily roll it around the shop. You can occasionally roll it outside and blow some compressed air in the 55 and expel any unwanted fumes. Get the wheels that are raw steel. They act as a ground.
Re: solvent tank, what solvent to use? [Re: A/MP] #2697126
09/13/19 10:00 AM
09/13/19 10:00 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Tell that to my fumes !!! The odor permeates through the whole shop Odor = fumes !!
Re: solvent tank, what solvent to use? [Re: pittsburghracer] #2697159
09/13/19 11:33 AM
09/13/19 11:33 AM
Quote
Yes I certainly would be as no filter contributed to it getting crudded up as bad as it was. good comprehensive info here guys! It sounds like mineral spirits might possibly be the way to go. I had thought about kerosene but all I know of here is premium K1 & it is a bit pricey. Thanks guys!
