7&1/4 axle interchange Q #2696762
09/11/19 11:33 PM
09/11/19 11:33 PM
RapidRobert Offline OP
Will SBP/BBP 7&1/4 axles interchange in the same housing? Thank you for your time
Re: 7&1/4 axle interchange Q [Re: RapidRobert] #2696848
09/12/19 10:45 AM
09/12/19 10:45 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
No. The BBP axles have a bigger bearing on them and will physically not fit in a SBP housing.
Re: 7&1/4 axle interchange Q [Re: slantzilla] #2696859
09/12/19 11:27 AM
09/12/19 11:27 AM
Slant thank you!
Re: 7&1/4 axle interchange Q [Re: RapidRobert] #2696874
09/12/19 12:28 PM
09/12/19 12:28 PM
Park Forest, IL
Park Forest, IL
wave
Re: 7&1/4 axle interchange Q [Re: RapidRobert] #2697455
09/14/19 12:32 PM
09/14/19 12:32 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
In my personal experience, the best exchange for a 7 1/4 is from the car to the scrap pile....lol. Just swap the whole thing out, housing, brakes and all, even though that's more trouble. PB Blaster is your friend on the spindly little u bolts.
Re: 7&1/4 axle interchange Q [Re: JDMopar] #2697468
09/14/19 01:25 PM
09/14/19 01:25 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
iagree
Re: 7&1/4 axle interchange Q [Re: forphorty] #2697716
09/15/19 10:59 AM
09/15/19 10:59 AM
We raced on it (4:10 welded spiders) to save 100 (iirc) lbs of unsprung over an 8&3/4 & it held up well till the car was wrecked & broke an axle & yes the wreck broke the axle (& more) not the other way around. A consideration was to switch to SBP if that would ease my search for a replacement as I have SBP rims available. With no interchange I will continue searching for a BBP replacement axle. Thanks guys.
Re: 7&1/4 axle interchange Q [Re: RapidRobert] #2697736
09/15/19 11:50 AM
09/15/19 11:50 AM
JDMopar Offline
JDMopar  Offline
I see 7 1/4's come up for free every now and then on FABO. I'm pretty sure you are on there too, so maybe keep an eye out and hoard them up if they are close enough to you. Good idea on saving weight! up
Re: 7&1/4 axle interchange Q [Re: JDMopar] #2697745
09/15/19 12:22 PM
09/15/19 12:22 PM
Park Forest, IL
Park Forest, IL
I have 2 complete BBP units at my shop that I have never been able to even give away. If you're not in a big hurry I can ship you a pair of axles. I won't be able to get down to my shop for a couple weeks because of work. wave
Re: 7&1/4 axle interchange Q [Re: slantzilla] #2698194
09/16/19 07:37 PM
09/16/19 07:37 PM
Slant that sounds like a plan! I'll send ya a PM
