solvent tank, what solvent to use?
#2696765
09/11/19 11:38 PM
09/11/19 11:38 PM
RapidRobert
30 gallon capacity. It's cleaned & ready to be replaced. what should I get? thank you for your time.
Re: solvent tank, what solvent to use?
[Re: RapidRobert]
#2696770
09/11/19 11:46 PM
09/11/19 11:46 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used to get my solvent from tractor supply but got tired of the stink. I switched to kerosene with zero complaints and a bonus is I use kerosene to burn several times a year so I can change out more often. I have a nice link saved from Yellowbullet on adding an oil filter to filter it if you are interested
[Re: RapidRobert]
#2696772
09/11/19 11:54 PM
09/11/19 11:54 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I only buy stoddard solvent, naptha is the same hazard class but it is not the same stuff. For me if I dont use gloves, stoddard solvent will make my hands tingle, naptha will not. It is a very standard industrial solvent. You can also look for PD680 type 2, it is an effective degreaser.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: RapidRobert]
#2696822
09/12/19 09:29 AM
09/12/19 09:29 AM
Posts: 1,104 Massillon, Ohio
cudatom
Massillon, Ohio
I buy mine direct from the machine shop I use. Not sure what brand but been doing this for 20 yrs.
Ok
[Re: cudatom]
#2696834
09/12/19 10:03 AM
09/12/19 10:03 AM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
ALWAYS ..wear rubber gloves, my doctor says the skin absorbs it and to your organs in minutes
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2696856
09/12/19 11:21 AM
09/12/19 11:21 AM
Posts: 2,673 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
ALWAYS ..wear rubber gloves, my doctor says the skin absorbs it and to your organs in minutes I'm with you
2011 Drag Pak Challenger
[Re: DynoDave]
#2696873
09/12/19 12:25 PM
09/12/19 12:25 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I use Shell solvent 360 or Stoddard, 5 to 10 gallons only
[Re: moparx]
#2696905
09/12/19 02:26 PM
09/12/19 02:26 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
i'm interested in the filter link if you could. TIA ! Wow I was starting to think I lost the link when my old computer bit the dust. I bought everything to do this but when I cleaned my tank last year I ended up fixing the pump that was in the tank new. One of these days I will finish the job. I hope Photobucket didn't mess up the guys pictures to bad. https://www.yellowbullet.com/forum/showthread.php?t=1083210&highlight=parts+washer+pump
[Re: pittsburghracer]
#2696946
09/12/19 05:05 PM
09/12/19 05:05 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I use mineral spirits in the big tank. When it gets to diluted and dirty, I put it in a separate tank that I use to pre-clean the really nasty dirty stuff to extend the life of the new, clean mineral spirits in the main tank. If performs well, no complaints. I use simple green and water in the ultrasonic cleaner. I always wear gloves before dipping my paws int any of this stuff. Now, since mineral spirits has gotten so expensive, Sometime I pour a little bit of gas in a bucket and clean stuff outside.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: A/MP]
#2696972
09/12/19 06:12 PM
09/12/19 06:12 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There's spray gun cleaner that does it all. You want a well ventilated shop for that stuff - and pitch the rags, etc outside afterwards. just opening the can will have the odor lingering for days !!
[Re: Stanton]
#2696979
09/12/19 06:26 PM
09/12/19 06:26 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a wall mount invented natural gas heater in my shop. Fumes from spray cans or strong tank cleaners are burnt by my heater and give off terrible fumes. Kerosene in my parts tank have helped with this
#2697159
09/13/19 11:33 AM
09/13/19 11:33 AM
RapidRobert
I have a nice link saved from Yellowbullet on adding an oil filter to filter it if you are interested Yes I certainly would be as no filter contributed to it getting crudded up as bad as it was. good comprehensive info here guys! It sounds like mineral spirits might possibly be the way to go. I had thought about kerosene but all I know of here is premium K1 & it is a bit pricey. Thanks guys!
