Stock Hemi intake #2696670
09/11/19 07:32 PM
09/11/19 07:32 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Anybody have the casting numbers by year 66-71 thanks
Re: Stock Hemi intake [Re: cudaman1969] #2696774
09/11/19 11:58 PM
09/11/19 11:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
All years have the same casting number but smaller details set them a part through the years
Re: Stock Hemi intake [Re: ScottSmith_Harms] #2696816
09/12/19 09:08 AM
09/12/19 09:08 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I agree! Still seem to read conflicting posts on the "P" stamping location/direction per year(s). Anyone know the final word?
68 Charger
70 Cuda
Re: Stock Hemi intake [Re: ScottSmith_Harms] #2696852
09/12/19 11:02 AM
09/12/19 11:02 AM
fredericksburg,va
fredericksburg,va
Mine has the big pentastar in front?
Since I’m new to these intakes, why the difference on the front holes on back carb, I know the engine just runs off the back carb till you nail it.
Re: Stock Hemi intake [Re: cudaman1969] #2696897
09/12/19 01:45 PM
09/12/19 01:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The P size and location varies, generally speaking the smaller P started in 1968, went to the larger style sometime in 69 and remained through 71. Location and clocking varied, likely random. They do not run on just the primary exclusively, the front carb (secondary) also has an idle circuit criticle to proper fuel distribution. The front to rear intake port variable is typical of a dual plane intake design, it has to do with proper fuel distribution at various rpms the first design without the Pentastar was the 1966 and early 1967 design, the Pentastar was added early in the 67 model year.
Re: Stock Hemi intake [Re: ScottSmith_Harms] #2696901
09/12/19 02:08 PM
09/12/19 02:08 PM
VA
dragon slayer Offline
VA
I think he is talking about the holes in the manifold. Most tuning recommendation is to add some idle rpm on the front carb so that you are not purely on the back at idle. But it is true that the back is doing the heavy lifting, with a progressive linkage that will not operate the front carb linkage at idle and low throttle application. I imagine that notch is to ensure some balance coming out of the rear carb primary venturi's at idle and low rpm. But no expert on that, just a guess.
Re: Stock Hemi intake [Re: dragon slayer] #2697008
09/12/19 08:57 PM
09/12/19 08:57 PM
A727Tflite Offline
A727Tflite  Offline
Thats exactly why the notch is there-
Re: Stock Hemi intake [Re: A727Tflite] #2697334
09/13/19 10:54 PM
09/13/19 10:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is a small "P" example, I've seen these on 67's and 68'
Re: Stock Hemi intake [Re: ScottSmith_Harms] #2697459
09/14/19 12:51 PM
09/14/19 12:51 PM
fredericksburg,va
fredericksburg,va
Do the heat holes have to be blocked off or just left open (using headers)
Re: Stock Hemi intake [Re: cudaman1969] #2697467
09/14/19 01:24 PM
09/14/19 01:24 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You can leave them open, they both go into one large chamber in the manifold.
