Reoccuring Leaky rear inner axle seals 8 3/4...UPDATED
#269638
03/28/09 03:33 PM
03/28/09 03:33 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
I've changed the rear axle inner seals at least 3 times in the past 2 years and for some reason the drivers side leak keeps coming back. I've even run a bead of silicone sealant around the seals and let them dry for 24 hrs before reinstalling the axle but resulted in no long term help. I'm going to attempt this for a 4th time this week and all I can think of is to polish the axle surface where it would contact the rubber seal. Any thoughts guys? Thanks! ![](/ubbthreads/images/graemlins/shruggy.gif)
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Reoccuring Leaky rear inner axle seals 8 3/4...
[Re: Hoof Hearted]
#269639
03/28/09 03:59 PM
03/28/09 03:59 PM
RapidRobert
I would measure & find the exact place on the axle where the seal hits & if it is smooth I would not sand it as that would make it smaller & more likely to leak. You might check with a dealer & see if they have one of the original type drivers that has a shaft that goes inside the seal in addition to the flat face of the driver contacting the seal flat. These distort the seal much less in addition to keeping the inner spring from being potentially popped off while being driven in. I fill the cavity where the spring is with heavy grease to hold the spring in place while being driven in
[Re: Hoof Hearted]
#269644
03/28/09 05:24 PM
03/28/09 05:24 PM
Hoof Hearted
S.E. Conn
Thanks for the replys thus far. I'm using standard axle bearings, no greens. There is nimimal end play when installed, maybe 1/16" to 1/8". Keep the pointers coming, there all welcomed as i'm ready to shotgun this thing. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: DoctorDiff]
#269646
03/28/09 05:59 PM
03/28/09 05:59 PM
Hoof Hearted
S.E. Conn
Sorry, NAPA brand. They slide in ok with minimal pressing (Wacking) yes, I have the correct tools, and they are in all the way...
How can I tell if my axles are bent?
[Re: Hoof Hearted]
#269647
03/28/09 06:04 PM
03/28/09 06:04 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
That is highly unlikely unless the car was wrecked. You would have much bigger problems from a bent axle than a leakng seal like wearing out bearings etc
[Re: Mr_fixit]
#269650
03/31/09 08:20 AM
03/31/09 08:20 AM
Make sure your vent is working properly. If it's not, the pressure will build up and blow it out a seal..... Make sure you don't have a solid bolt where the vent bolt is supposed to go. I did that once and learned ...
I totally agree. I had the very same problem with a 9 1/4 rear in my 4X4. It drove me nuts. I replaced the seals several times and even replaced the axle trying to find the problem. I finally found the rear vent had been replaced, by the previous owner, with a bolt. I don't know how I didn't notice it before I did. The strange part was it only leaked on the drivers side. Once I replaced the bolt with the correct vent the problem was fixed for good. That was a first for me but I've never forgotten it. It's worth looking to see if your vent is plugged or if it's even there at all. Good Luck.
#269651
03/31/09 09:56 PM
03/31/09 09:56 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Good point on checking the vent.
About making sure the seal is bottomed out. Is there enough surface on the axle to try this idea.
It will take some extra effort to make sure the seal is square to the housing but what if you don't bottom out the seal. Then the lip will be sealing on an unused portion of the axle.
[Re: Mr_fixit]
#269652
03/31/09 10:37 PM
03/31/09 10:37 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Make sure your vent is working properly. If it's not, the pressure will build up and blow it out a seal..... Make sure you don't have a solid bolt where the vent bolt is supoosed to go. I did that once and learned ...
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: dave571]
#269653
04/04/09 04:42 PM
04/04/09 04:42 PM
Hoof Hearted
S.E. Conn
Thanks for the helpful replies.
Here's some pics, I think I found the problem(I Hope):
[Re: Hoof Hearted]
#269654
04/04/09 04:46 PM
04/04/09 04:46 PM
Hoof Hearted
S.E. Conn
Here's pic of the Axle Housing Vent Cap. I removed the cap and thoroughly cleaned it and the housing out. I think it was the scrape in the axle allowing the gear fluid to bypass the seal.
I destroyed the seal while removing it(before I noticed the axle scrape) and of course it's Saturday afternoon and NAPA is closed...
