New PB and a wheelstand Vid
#2695839
09/09/19 04:10 PM
09/09/19 04:10 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Hi All. We ran a PB over the last weekend keeping up the New PB every meeting this year. It's ran a 9.51 which is a PB for the 572 motor mph is the same so its all down to the chassis. Here's the Vid https://www.youtube.com/watch?v=D4B_QewPIhc
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: New PB and a wheelstand Vid
[Re: Cab_Burge]
#2695870
09/09/19 05:12 PM
09/09/19 05:12 PM
Tig
A shed in England
We've found lowering the wheelie bar unloads the tyre when the bars stop, It's uses a radial tyre. It's a fine line between wheelstanding and spinning,you can just see it unloading around 40 seconds in. We would be better off with the Caltrac mono bar than the axle mount wheelie bars fitted now but have the tank in the stock position. thanks Bigdad for putting up the link
[Re: Tig]
#2696042
09/10/19 08:11 AM
09/10/19 08:11 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Looking good Tig!! I was gonna say that I bet lowering the bars will unload it. Looks like the radials are working for you! Tighten up those front shocks to keep the front down.
[Re: an8sec70cuda]
#2696149
09/10/19 01:39 PM
09/10/19 01:39 PM
Tig
A shed in England
Looking good Tig!! I was gonna say that I bet lowering the bars will unload it. Looks like the radials are working for you! Tighten up those front shocks to keep the front down. Thanks Chip. We turned another flat for tighter extension after that one, we were into a headwind the next day. Less height but then span on the last two passes.
