Re: Oil pan repair?
[Re: racerx]
#2695134
09/07/19 08:48 AM
09/07/19 08:48 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Brake clean, blow out cracks with air, wire brush, brake clean, blow out with air, propane torch until sweat is gone, weld. Make sure to keep the pan fastened to something rigid... preferably a spare block. Aluminum moves a lot when welding.
Re: Oil pan repair?
[Re: TRENDZ]
#2695137
09/07/19 09:03 AM
09/07/19 09:03 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You know of course that this is going to bring out all of the stories about brake clean, tig welding and death.
2011 Drag Pak Challenger
Re: Oil pan repair?
[Re: rickseeman]
#2695162
09/07/19 10:32 AM
09/07/19 10:32 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You know of course that this is going to bring out all of the stories about brake clean, tig welding and death. Yep. Believe it or not some people still don’t know about the dangers. Until it’s to late.
Re: Oil pan repair?
[Re: FastmOp]
#2695226
09/07/19 01:10 PM
09/07/19 01:10 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
No brake clean, unless you're the type to play with loaded guns too.
Acetone or a dedicated aluminum cleaner from the weld supply shop. A clean, stainless brush. Aluminum, especially cast, will absorb whatever fluid it's in contact with to some degree. You may find that you have to get it wet with the torch and clean off the poop and crap that comes up out of the metal multiple times before you can get a bead to run. Using the propane torch also helps.
If it's cracked through a bead or a thick piece, V'ing the crack will help.
Re: Oil pan repair?
[Re: CMcAllister]
#2695275
09/07/19 05:13 PM
09/07/19 05:13 PM
Posts: 4,209 New York
polyspheric
New York
What he said
Boffin Emeritus
Re: Oil pan repair?
[Re: pittsburghracer]
#2695305
09/07/19 09:03 PM
09/07/19 09:03 PM
TRENDZ
Milwaukee WI
Argon at high temps is the issue. I don’t want anyone to be harmed using only part of my advice. Read my entire instructions and there is no issue. Better yet... just ignore me.
Re: Oil pan repair?
[Re: justinp61]
#2696019
09/10/19 05:39 AM
09/10/19 05:39 AM
Posts: 4,072 Mo.
racerx
Mo.
Most people use green, pure tungsten. I use blue, 2% lanthanted for everything, steel or aluminum. Thaxs…..was reading on this and was told green was used for the non -inverter type machine(older ones )some say they used orange. I'v tried purple with no luck.it work with cromemoly tho.
