Oil pan repair? #2695123
09/07/19 07:43 AM
09/07/19 07:43 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
For the DIY's on here when tig welding aliuminum oil pans what do youall use to clean it before welding it?
Re: Oil pan repair? [Re: racerx] #2695127
09/07/19 08:06 AM
09/07/19 08:06 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Stainless wire brush
Re: Oil pan repair? [Re: racerx] #2695128
09/07/19 08:07 AM
09/07/19 08:07 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Stainless brush & acetone
Re: Oil pan repair? [Re: racerx] #2695134
09/07/19 08:48 AM
09/07/19 08:48 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Brake clean, blow out cracks with air, wire brush, brake clean, blow out with air, propane torch until sweat is gone, weld.
Make sure to keep the pan fastened to something rigid... preferably a spare block. Aluminum moves a lot when welding.
Re: Oil pan repair? [Re: TRENDZ] #2695137
09/07/19 09:03 AM
09/07/19 09:03 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You know of course that this is going to bring out all of the stories about brake clean, tig welding and death.
2011 Drag Pak Challenger
Re: Oil pan repair? [Re: rickseeman] #2695138
09/07/19 09:10 AM
09/07/19 09:10 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Still here.
Re: Oil pan repair? [Re: rickseeman] #2695145
09/07/19 09:38 AM
09/07/19 09:38 AM
New York
polyspheric Offline
polyspheric  Offline
New York
MEK, Gun Scrubber
Boffin Emeritus
Re: Oil pan repair? [Re: rickseeman] #2695162
09/07/19 10:32 AM
09/07/19 10:32 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Yep. Believe it or not some people still don’t know about the dangers. Until it’s to late.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Oil pan repair? [Re: pittsburghracer] #2695182
09/07/19 11:22 AM
09/07/19 11:22 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Some break cleaner doesn't have clorine
Re: Oil pan repair? [Re: FastmOp] #2695226
09/07/19 01:10 PM
09/07/19 01:10 PM
Fulton County, PA
CMcAllister Offline
CMcAllister  Offline
Fulton County, PA
No brake clean, unless you're the type to play with loaded guns too.
Acetone or a dedicated aluminum cleaner from the weld supply shop. A clean, stainless brush. Aluminum, especially cast, will absorb whatever fluid it's in contact with to some degree. You may find that you have to get it wet with the torch and clean off the poop and crap that comes up out of the metal multiple times before you can get a bead to run. Using the propane torch also helps.
If it's cracked through a bead or a thick piece, V'ing the crack will help.
Re: Oil pan repair? [Re: CMcAllister] #2695275
09/07/19 05:13 PM
09/07/19 05:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What he said
Boffin Emeritus
Re: Oil pan repair? [Re: polyspheric] #2695302
09/07/19 08:51 PM
09/07/19 08:51 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
All metals will absorb oil. Wash with water based degreaser and bake in over at 400* for 5 hours. After cooldown, acetone wash, grind, acetone wad and weld. Makes the welding easier.
Re: Oil pan repair? [Re: pittsburghracer] #2695305
09/07/19 09:03 PM
09/07/19 09:03 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Argon at high temps is the issue. I don’t want anyone to be harmed using only part of my advice. Read my entire instructions and there is no issue.
Better yet... just ignore me.
Re: Oil pan repair? [Re: TRENDZ] #2695931
09/09/19 08:33 PM
09/09/19 08:33 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the replies fellas...…………..one more ?...….what Tungsten is use for aluminum?
Re: Oil pan repair? [Re: racerx] #2695965
09/09/19 10:07 PM
09/09/19 10:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Most people use green, pure tungsten. I use blue, 2% lanthanted for everything, steel or aluminum.
Re: Oil pan repair? [Re: justinp61] #2696019
09/10/19 05:39 AM
09/10/19 05:39 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs…..was reading on this and was told green was used for the non -inverter type machine(older ones )some say they used orange. I'v tried purple with no luck.it work with cromemoly tho.
