STRUT ROD BUSHINGS #269502
03/28/09 12:17 PM
03/28/09 12:17 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
i was looking at my strut rod bushings and they are shot.....just ordered new ones...poly...whats the best way to do this job....any helpful tips would be great....thanks
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269503
03/28/09 12:36 PM
03/28/09 12:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You'll be putting car on stands and backing the torsion bars off and sliding them backwards for one thing. Lower arm pivot nuts will have to be removed and backed outta there also.
Re: STRUT ROD BUSHINGS [Re: buildanother] #269504
03/28/09 04:06 PM
03/28/09 04:06 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
do i have to remove the lower control arms or can i just pry them back enough to slide rods out??
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269505
03/28/09 07:16 PM
03/28/09 07:16 PM
chicagoland,usa
chicagoland,usa
You might be able to slide them back just enough to drop the control arm end of strut first, then wiggle the front out of k frame. Of course, you'll be taking that 3/4 inch nut off the strut first. Those are usually stuck in there a little and may have to be knocked loose.
Re: STRUT ROD BUSHINGS [Re: buildanother] #269506
03/28/09 09:59 PM
03/28/09 09:59 PM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
You will also have to disconnect your front shocks from the lower control arms along with the front sway bar links and lower ball joints
Re: STRUT ROD BUSHINGS [Re: manymopars] #269507
03/28/09 10:35 PM
03/28/09 10:35 PM
If your strut rod bushings are shot, I bet the lower control arm bushings are shot too.......and since you have to pull the lower arms out to change the strut rod bushings, now's the time to change the lower control arm bushings.....
Re: STRUT ROD BUSHINGS #269508
03/28/09 11:37 PM
03/28/09 11:37 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
guys thanks for your help....sounds like i am in for some fun
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269509
04/09/09 11:11 PM
04/09/09 11:11 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
question on the bushings.....the beveled side goes out to the washer....right??.....also did you have to cut the bushing on the beveled side to make it work ....looks fat compared to whats left of the old bushings
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269510
04/10/09 09:47 AM
04/10/09 09:47 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269511
04/10/09 10:21 AM
04/10/09 10:21 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i didn't do this as i have a b body but it's interesting. http://users.erols.com/mathewg/bushings.html
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269512
04/10/09 11:34 AM
04/10/09 11:34 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I had to thin mine on the belt sander to make them work. This was on a c-body, though.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: STRUT ROD BUSHINGS [Re: Fury Fan] #269513
04/10/09 10:45 PM
04/10/09 10:45 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
it seems that the b-body is the only one that doesnt have to trim them....
Re: STRUT ROD BUSHINGS [Re: GEORGE68HEMIRR] #269514
04/11/09 08:59 AM
04/11/09 08:59 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
WOW what timing. This place never ceases to amaze me. I have been fighting this issue all week. I just figured I had the wrong bushings. Pics later.
Re: STRUT ROD BUSHINGS [Re: belv2vert66] #269515
04/14/09 11:44 PM
04/14/09 11:44 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
well i got back into it and was a piece of cake...took off the nuts off the strut rod,released torsion bar adjuster,removed rear torsion bar clip,removed lower control arm nut,poped upper ball joint,pryed back control arm which slide back the torsion bar in the socket and bingo...out came the strut rod....wasnt bad at all
