1973 340 Thermquad Leaks after Shutting Off, Help! #2694985
09/06/19 02:24 PM
09/06/19 02:24 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
340 TQ started leaking fuel into the intake after I shut the car off. Then almost impossible to start without holding peddle wide open while cranking, followed by that rich, fuel smelling, smokey, start. I'm hoping someone here can get me close to where and what the problem is inside the carb. After shutting down the engine, I immediately checked inside the the carb and found that there was NO leaking above throttle plates. A little wet, but no leaks. When I cracked the throttle plates, and looked down past the butterflies, the intake is soaking wet with fuel, So the leak must be coming somewhere below the butterflies, right? Does that mean my floats are sealing and adjusted adjust ok, and its as base plate gasket leak or something else down there? No too familiar with TQs, but I hear they are prone to leaking for a bunch of reasons.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RSI700VIPER] #2695007
09/06/19 03:32 PM
09/06/19 03:32 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Probably the well's on the bottom of the bowl under the main jets unless a leaking needle/seat,a cracked bowl also but not common.There are no other ways for a leak other than mentioned.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: 62maxwgn] #2695016
09/06/19 04:09 PM
09/06/19 04:09 PM
NW New Jersey
NW New Jersey
62max - When you say "Probably the well's on the bottom of the bowl under the main jets" is this a gasket or an o-ring change or something more serious? I read somewhere that there are parts that are epoxy glued to the bottom of the bowl.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RSI700VIPER] #2695024
09/06/19 04:42 PM
09/06/19 04:42 PM
Quote
Yes, pull the carb & you will see if it is leaking out of those wells
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RapidRobert] #2695029
09/06/19 05:03 PM
09/06/19 05:03 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
There are seals under the long primary jets that can go bad too, but it's most likely the expoxied wells that start leaking overtime.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: BigBlockMopar] #2695045
09/06/19 06:02 PM
09/06/19 06:02 PM
5thAve Offline
5thAve  Offline
Those wells have some sort of glue to hold them in place. That's what was leaking when I had problems years ago. But it was a rebuilt carb so I sent it back for another one.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: 5thAve] #2695047
09/06/19 06:28 PM
09/06/19 06:28 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content
moparmike1  Online Content
Scott Smith Harms at Harm's Automotive is someone you should speak to. He restores Thermoquads and repairs the leak being described.
Your TQ will come back looking like a piece of art!
Mike.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: moparmike1] #2695072
09/06/19 09:39 PM
09/06/19 09:39 PM
NW New Jersey
NW New Jersey
Mike,
I'm sure Scott does a great job but just looking for a quick fix to get me through the season.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RSI700VIPER] #2695075
09/06/19 09:45 PM
09/06/19 09:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The other guys posting have likely found the answer, the fuel well plugs could be leaking or an O ring is either degraded and leaking or installed incorrectly. wrench
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: ScottSmith_Harms] #2695088
09/06/19 10:42 PM
09/06/19 10:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Had to stick in the O rings I forgot didn't ya !! beer
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: 62maxwgn] #2695122
09/07/19 07:30 AM
09/07/19 07:30 AM
NW New Jersey
NW New Jersey
Scott, would I be able to see the fuel leaking for either condition by looking down into the venturies? The carb was rebuilt 3 years ago and has been trouble free until now.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RSI700VIPER] #2695171
09/07/19 10:59 AM
09/07/19 10:59 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Is the carb subjected to a lot of heat ?
In my experience- I have never seen bowl issues - I’m not saying it doesn’t happen- jsta my experience.
The first thing I would have looked for is sunken floats.
But if there’s no appreciable leakage above the butterflies.., bowl issues are to be looked at.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: BeEtLeJuIcE !] #2695263
09/07/19 04:22 PM
09/07/19 04:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You would not normally see it looking down the venturis if the wells were leaking. Also, what Doc said about the floats would be correct, if you see fuel up high running out of the vents or shafts, etc. it's nearly always a float related issue.
It sounds like the glue used to put the fuel well plugs in has failed causing a leak but that's just my "1000 mile away" guess smile
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: ScottSmith_Harms] #2695397
09/08/19 10:16 AM
09/08/19 10:16 AM
moparx Offline
moparx  Offline
scott, what do you use to glue the fuel well plugs ? i have used JB before with good results, and now there are a bunch of JB formulas to choose from.
is the loctite better, or do you prefer something else ?
beer
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: RSI700VIPER] #2695442
09/08/19 12:50 PM
09/08/19 12:50 PM
IMGTX Offline
IMGTX  Offline
At the bottom of the fuel bowl under the primary jets is a elongated cap that directs fuel from the jets to the feed tubes to the primary venturis. It is epoxied to the bottom of the bowl.
The feed tubes are cast into the top aluminum body and between the bowl and the feed tubes are "X" rings. Orings with a cross section of an X.
I have found that most often the o-ring (x-ring) goes bad. However the epoxy is known to leak too.
If you remove the top and the o-rings are shot, a simple rebuild will fix it. If the o-rings look good then rebuild it and put fresh epoxy around the elongated cap under the bowl. It will need to fit in the well of the base so don't go crazy. I do not know of a good type of epoxy but there are many fuel tank epoxies that may work. Hopefully someone will chime in with a good brand.
The first two Thermoquads I have rebuild I over tightened the top and crushed the X-rings. DO NOT OVER TIGHTEN THE TOP. Gentle gentle gentle. You can always snug it a little more later if it leaks out the sides of the top when cornering but you can not buy those X-rings with out the $35 kit. If anyone knows where to get them individually I would love to know.
Or you can send it to Scott and have a perfect one returned.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: moparx] #2695465
09/08/19 01:54 PM
09/08/19 01:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have used several types of epoxy, as long as it is spec out as a fuel resistant formula, and all directions for prep & curing time are followed, any of them should work fine (JB fuel resistant, Loctite 401, etc.). Loctite 401 works very well and is my current choice.,
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: IMGTX] #2695468
09/08/19 02:06 PM
09/08/19 02:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
G902 Primary Well Seal, $3.00
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: Sniper] #2695474
09/08/19 02:38 PM
09/08/19 02:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are conventional o-rings that work just as well as long as the diameter and thickness are the same and resistant to fuel as most are. I have used them periodically at times since the advent of the T/Q when I had no immediate access to originals and "never" had an issue.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: Sniper] #2695476
09/08/19 02:43 PM
09/08/19 02:43 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Take it apart and fill the plastic main body with enough water to see if the wells seep. If they seep, carefully remove the wells and scrape off the old glue and glue them back on using SEAL ALL.
Re: 1973 340 Thermquad Leaks after Shutting Off, Help! [Re: Sniper] #2695480
09/08/19 02:58 PM
09/08/19 02:58 PM
IMGTX Offline
IMGTX  Offline
Thank You up That rocks
