Always check #2694064
09/03/19 06:17 PM
09/03/19 06:17 PM
central il.
second 70 Offline OP
central il.
I took my carbs off today to clean and to be sure all air bleeds and passages were open and also try a different tune.
Glad I was paying attention 3 out of 4 new rods were fine but 1 had the lean part of the rod machined too high and would have left it on power step. I don’t know if you can see the numbers on the rod is right but totally different stamping.
Got lucky that situation would have been fun to chase.
Re: Always check [Re: second 70] #2694183
09/04/19 12:01 AM
09/04/19 12:01 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Good catch! If you were not tuning you might have seen that !!,,,,,and I'm a Holley guy turned SV!.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
