E 85 or .125 cometic for pump gas #2693666
09/02/19 03:23 PM
09/02/19 03:23 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Motor is 13.2 cp looking going to pump gas or e 85. I have a HP 1000 i could convert to e85. Did not know if that thick of head gasket would work. If i go to pump gas will also change cam. Thanx in advance JIM
Re: E 85 or .125 cometic for pump gas [Re: 71Pan] #2693763
09/02/19 08:51 PM
09/02/19 08:51 PM
SoCal
Brian Hafliger Offline
SoCal
If your sure it's a true E85, you should be fine...make sure you have a good pump, and proper fuel line size to accommodate the need for more volume.
Brian Hafliger
Re: E 85 or .125 cometic for pump gas [Re: Brian Hafliger] #2693766
09/02/19 08:53 PM
09/02/19 08:53 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Look into water/meth injection with premium pump junk up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: E 85 or .125 cometic for pump gas [Re: hemi-itis] #2693905
09/03/19 11:11 AM
09/03/19 11:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
E85 is a great fuel. If its readily available around you I would not hesitate. Get a fuel tester to check consistentsie.
Re: E 85 or .125 cometic for pump gas [Re: fbs63] #2694078
09/03/19 06:53 PM
09/03/19 06:53 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I'd opt for corn. I really love it for a fuel. Even cost excluded, corn makes more power than pump, runs cool, and no where near as bad to breathe.
Cheaper
faster
safer
cooling
All those benefits for a very small amount of carb corrosion. I have E85 carbs that are 15 years old that work as good as the day they were made.
