TKO600
#2693492
09/01/19 07:21 PM
09/01/19 07:21 PM
Posts: 46 Edmonton , Alberta
swingin
Edmonton , Alberta
So, I installed a TKO600 in my Swinger earlier this year, and I've been struggling with a persistent leak at the speedo cable entry into the tail shaft. First I thought it was a compromised o-ring, so I put a new one on. No good. I had a spare cable on hand, so I installed it, and it looked as if that may have fixed the problem, but after about 150km of highway driving, the leak re-appeared. So, tore it apart again, and found that there was gear fluid inside the cable jacket, and I'd almost bet that its leaking out where the jacket has been crimped onto the gear assembly. No techs I've spoken to at various Tremec dealers have been able to shed any light on this problem, so I'm just throwing it out here. Surely somebody here has a Tremec, maybe somebody here has seen this problem, or knows of somebody who has?
