Re: Block casting stress cracks
[Re: racerx]
#2693621
09/02/19 12:02 PM
09/02/19 12:02 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I've seen 3 RB blocks (1 426M.W and 2 pre 1973 440 blocks) cracked in the main webs between #1 and #3 cylinders into the # 2 main webbing IHTHs
[Re: racerx]
#2694683
09/05/19 12:30 PM
09/05/19 12:30 PM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
If your talking were the tail of the skirts are, that area can get severely beat up when a rod is kicked but I have knocked any rough edges off and reused the block . So a small crack in that area wouldn't be a big deal to me, if its small enough you probably could remove it. B1MAXX....not sure if I understand your response (When a rod is kick out)Or you saying when a rod is kick out the block? Thrown a rod? You said where the skirt comes out of the block that area is perpendicular to the web. Is the crack on the web side of the bore, or the skirt?
