Will a nag1 bolt up to a 09+ truck 5.7 ok? #2693301
08/31/19 11:15 PM
08/31/19 11:15 PM
IL
furious70 Offline OP
IL
Continuing to look for a 5.7/nag1 combo for my Fury and it looks like buying a truck 5.7 to get the alt out of the a arm and a nag1 separate might be actually cheaper than a car take out anyway. Are there any differences that would keep a nag1 from bolting up and working with a truck 5.7?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Will a nag1 bolt up to a 09+ truck 5.7 ok? [Re: furious70] #2693345
09/01/19 08:04 AM
09/01/19 08:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Bolting up shouldn't be an issue. Whether the ECM will run it is another matter entirely. If not maybe a swap to a car ECM. There is a guy in Germany that sells a stand alone unit to run that transmission but it's pricey.
Kevin
Re: Will a nag1 bolt up to a 09+ truck 5.7 ok? [Re: Twostick] #2693364
09/01/19 08:58 AM
09/01/19 08:58 AM
IL
IL
I'll be turbocharging so I'll be using ms3, hotwire, and the sound German controller, yes
70 Sport Fury
68 Charger
69 Coronet
72 RR
