1970 gran coupe rocker molding.. #2693231
08/31/19 06:49 PM
08/31/19 06:49 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Most likely a dumb question.....the slats. They face pointing up (so you can see the grooves? Or face down. Where you can't see the grooves?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 1970 gran coupe rocker molding.. [Re: toplescuda] #2693235
08/31/19 07:00 PM
08/31/19 07:00 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Does this help
Re: 1970 gran coupe rocker molding.. [Re: 70 buzz] #2693248
08/31/19 07:55 PM
08/31/19 07:55 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Not really. Can't see the molding well enuff
The slats where you can see down between the slats. ?
The molding on the right in the pic. Would the left side of it go up. Or be facing down toward the road?
They were not on the car when got it
1971 charger
Re: 1970 gran coupe rocker molding.. [Re: toplescuda] #2693280
08/31/19 10:18 PM
08/31/19 10:18 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I believe they face up. The mldg on the left in your photo is showing the front of it - where it meets the RH fender lip. See the angle where it follows the wheel opening?
