Re: 6.4 BGE crate motor with a 274 comp cam
[Re: biff426]
#2691906
08/27/19 12:10 PM
08/27/19 12:10 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Back in Jan I was over at my builders place he had a 2018 SRT392 Non MDS Crate engine on the dyno(superflo 901) for some NA intake testing with the stock long block, only mod was locked cam..Peak Hp with the DragPak was 580 @ 6900 , and Tq was 490 at 4700ish. Ritter intake was 570ish at 6900 and Arrow/prefix was high 54X at 6800. Then came cam testing ,With Comp Cams 274, DP intake, a Get em Garage dual blade Carb ,MSD 6 on 91 oct it did 605 @ 6900 one of the other cams tested Texas Speed NA Stage 4 Camshaft (.582/.582, 226/235@50 117 CL) with the DP and Carb made 585 @ 6600.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2691962
08/27/19 02:21 PM
08/27/19 02:21 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I always suspected the 392 SRT with real exhaust and tall style intake would be a shade under 600 HP. The BGE with a cam swap only gives up some compression so it should not be too far down from that.
[Re: WO23Coronet]
#2692426
08/28/19 09:26 PM
08/28/19 09:26 PM
Ray408G3Hemi
Springtown Pa
A stock 392 cam made 580 hp? Where was it installed? Locked the cam straight up, for the 580 pull, and then back 2 degrees, I've seen him skip a tooth then move the Phaser back and lock it with machine spacer blocks.
[Re: Ray408G3Hemi]
#2692440
08/28/19 10:01 PM
08/28/19 10:01 PM
Posts: 1,543 USA
hudsonhornet7x
USA
A stock 392 cam made 580 hp? Where was it installed? Locked the cam straight up, for the 580 pull, and then back 2 degrees, I've seen him skip a tooth then move the Phaser back and lock it with machine spacer blocks. Any videos? How did it idle?
[Re: 03heavy]
#2692622
08/29/19 01:49 PM
08/29/19 01:49 PM
HotRodDave
Kalispell Mt.
I've done it, no issue. It does have a slightly noticeable idle but it is a pretty big cam especially for a 5.7 MDS or not. If your buying a new 6.4 cam get the non MDS cam if your not going to run MDS.
[Re: Ray408G3Hemi]
#2692667
08/29/19 04:55 PM
08/29/19 04:55 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
A stock 392 cam made 580 hp? Where was it installed? Locked the cam straight up, for the 580 pull, and then back 2 degrees, I've seen him skip a tooth then move the Phaser back and lock it with machine spacer blocks. I read in the post that "Peak Hp with the DragPak was 580". So the stock short block had a DP cam, or it was a stock 392 cam? I didn't think the DP cam would clear without notches in the pistons. Either/or, pretty impressive for mostly stock stuff!
[Re: cudadoug]
#2692669
08/29/19 05:05 PM
08/29/19 05:05 PM
HotRodDave
Kalispell Mt.
based on ET VS weight or MPH VS weight the 392 cars are pushing at least 500 bone stock with significant gains from intakes, exhausts, tuning, gears... typical bolt on stuff.
[Re: WO23Coronet]
#2693199
08/31/19 05:00 PM
08/31/19 05:00 PM
HotRodDave
Kalispell Mt.
I think the 392 SRT cam is around 220@.050 .577 ish lift. Not huge but big enough when you consider the low lift flow allowed from an un-shrouded valve moving away from the cylinder wall as well as a straight shot at the entire back of the valve.
[Re: HotRodDave]
#2697386
09/14/19 08:07 AM
09/14/19 08:07 AM
Ray408G3Hemi
Springtown Pa
I think the 392 SRT cam is around 220@.050 .577 ish lift. Not huge but big enough when you consider the low lift flow allowed from an un-shrouded valve moving away from the cylinder wall as well as a straight shot at the entire back of the valve. SRT8 392 camshaft is Part # 05037379BC. NON MDS 215/221 @ .050" .574"/.551" valve lift 1.6 intake/1.65 E ratio 121 LSA 108 ICL SRT8 392 MDS 05038419AB @50 Exhaust 215 on 4 lobes for MDS The SRT392 spec 591/559 , it uses 1.65 as a Intake ratio,Not 1.60 I've been a long time Ford guy , my kid and buddy got me in to these G3s the potential for the G3 is just awesome. My 496 FE makes about 690 hp, my 408 G3 makes about 690 Hp both do it with very similar cam specs.
[Re: biff426]
#2731952
01/10/20 08:27 PM
01/10/20 08:27 PM
Posts: 668 IL
Dart451
IL
