Re: Hooker kissing box
[Re: Milan454]
#2692049
08/27/19 07:46 PM
08/27/19 07:46 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Motor mount shims may solve ur header clearance issues... Schumacher used to sell a kit but their website says out of stock. But they are EZ to make.. Just my $0.02...
[Re: Milan454]
#2692202
08/28/19 09:48 AM
08/28/19 09:48 AM
Posts: 12,025 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You may try loosening the motor mounts and the steering box to see if they will move enough to give you the clearance you need.
Master, again and still
[Re: DaveRS23]
#2692211
08/28/19 10:04 AM
08/28/19 10:04 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I made some changes after I coated my B1 headers and had an issue with starter clearance. I found the proper radius that I needed on a piece of scrap on my scrap pile and used my Harbor Freight press to make some clearance. Sure beat doing it with a hammer.
