69 Charger rear seat question. #2691465
08/26/19 08:40 AM
08/26/19 08:40 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Is a 69 Charger rear seat different than other 2 door B-bodies 68-70? I'm not talking about the covers and the pattern but more the frames and the foam. I think the backs are all the same, I know the bottom of a 4 door is different but and for some reason I think the Charger bottom is different too. So who knows the truth?
Thanks in advance, Kevin
Careful, your character's showing!
Re: 69 Charger rear seat question. [Re: mopar346] #2691574
08/26/19 01:33 PM
08/26/19 01:33 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Same-to further expand they all use the same rear floor pan part # 2900801. This applies to 2 door sedan, hardtop, convert and yes even 4 doors just not wagons. it's in section 23-32-24 of the parts manual if you wanna check it out,
Re: 69 Charger rear seat question. [Re: Paul Jacobs] #2691681
08/26/19 07:43 PM
08/26/19 07:43 PM
mopar346 Offline OP
mopar346  Offline OP
Thank you. The 4 door rear seat base is different though correct?
Re: 69 Charger rear seat question. [Re: mopar346] #2691682
08/26/19 07:54 PM
08/26/19 07:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Bring yours by to compare, I have a set out of one of my 4-doors right now.
It would be cool to note the differences.
Re: 69 Charger rear seat question. [Re: Alaskan_TA] #2691810
08/27/19 06:13 AM
08/27/19 06:13 AM
mopar346 Offline OP
mopar346  Offline OP
I'll see if I can get it in the overhead next time I fly up. I actually have a rear seat out of a four door in a 68 RR but it's tucked in a back corner, I think it's something about the corner being rounder on a 4 door since you get in from the side instead of straight on from entering the front doors.
Re: 69 Charger rear seat question. [Re: mopar346] #2691902
08/27/19 11:50 AM
08/27/19 11:50 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
You are correct you need to stick with the standard two door seat
Re: 69 Charger rear seat question. [Re: Paul Jacobs] #2691908
08/27/19 12:12 PM
08/27/19 12:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
4-door bottoms have a rounder shape at the outer corners to ease ingress/egress.
Charger rear seat bottom & top (properly termed cushion & back) are same as 2-door Belvedere & Coronet lines, I've seen them interchanged.
Re: 69 Charger rear seat question. [Re: topside] #2691933
08/27/19 01:17 PM
08/27/19 01:17 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks folks.
