Brake flare kit recommendations #2691584
08/26/19 02:26 PM
08/26/19 02:26 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
I am making a complete new set of brake lines for my A100 due to installing the Scarebird kit. I purchased some S.U.R.&R. BR-EZ100 Brake Line tubing which is quite easy to bend, but I have not been able to find a decent flaring kit that works. Granted, they were all made in China. Can someone recommend a good kit?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Brake flare kit recommendations [Re: BloFish] #2691587
08/26/19 02:30 PM
08/26/19 02:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Mastercool 71475. Not cheap.
https://www.youtube.com/watch?v=schuHl6OC3w&t=328s
Combine it with a lapping tool and you're leak free.
https://koultools.com/product/flare-lapping-tool/
Re: Brake flare kit recommendations [Re: John_Kunkel] #2691598
08/26/19 03:06 PM
08/26/19 03:06 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yup as a fleet mechanic I find myself having to make alot of brake lines, finally got one of those master cool hydro tools, I like it, look around prices vary widely, look at some of the online tool sellers, eBay and Amazon, don't be in a hurry to get the 1st one you see, you'll save some cash. I've found some specialty tools on eBay and CL that were used like once and the seller either got out of the business or died and you get lucky and get it cheap.
I've used the old hand double flare tools for years,
Sometimes those fit into a tight space a bit easier than the Master cool one.
Re: Brake flare kit recommendations [Re: volaredon] #2691629
08/26/19 04:13 PM
08/26/19 04:13 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Thanks guys
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Brake flare kit recommendations [Re: BloFish] #2691661
08/26/19 05:55 PM
08/26/19 05:55 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
When I made all new lines for my '55 Plymouth, I bought the on-car tool from Eastwood and was very pleased with it.
Re: Brake flare kit recommendations [Re: 71charger] #2691668
08/26/19 06:30 PM
08/26/19 06:30 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Funny, I just ordered that about 30 minutes ago. This may well be my final brake line job, so I don’t want to spend more than I need. I just need a quality tool for the job.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Brake flare kit recommendations [Re: BloFish] #2691825
08/27/19 07:32 AM
08/27/19 07:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a Blue Point set I bought from SnapOn.Used it for over 30 years at work and home.My son bought a set from sumit that was clearanced like 15 years ago.It works great also.Rocky
Chrysler Firepower
Re: Brake flare kit recommendations [Re: John_Kunkel] #2691891
08/27/19 11:25 AM
08/27/19 11:25 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My buddy is an experienced aircraft mechanic. He states it is vital to lap and polish freshly made flares to remove any stress risers that can lead to splitting at the flare. I rarely do this, and have not seen any of my flares split. He either apparently has or its an industry standard training protocol.
I do tighten and loosen the jam nuts half a dozen times to better seat them. They tend to get tighter and turn in farther until the 3rd or 4th tightening cycle..
Re: Brake flare kit recommendations [Re: jbc426] #2691936
08/27/19 01:25 PM
08/27/19 01:25 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I'm a non-practicing A&P, and concur with your buddy. For aviation applications. Aircraft endure far more sustained cyclical vibration, particularly prop driven piston engine aircraft. Risers will turn into cracks in no time, anywhere (ever wonder why jet liners have rounded window corners as opposed to 90*). In my decade as a general aviation mechanic, I saw my share of brake lines with cracked flares having been properly lapped. I was trained to, harangued and nagged to and so just always did it. If there are any imperfections in the flare, they may last 10 years on the calendar, but probably less than 100hrs in the air.
Re: Brake flare kit recommendations [Re: BcudaChris] #2691965
08/27/19 02:35 PM
08/27/19 02:35 PM
Rio Linda, CA
Rio Linda, CA
I wonder how many of those were caused by over-tightening. I can count on one finger the number of techs I've seen (including me) who use a torque wrench on flare nuts.
Re: Brake flare kit recommendations [Re: John_Kunkel] #2691968
08/27/19 03:02 PM
08/27/19 03:02 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
most don't even have the right tool to torque a flare nut
Re: Brake flare kit recommendations [Re: Sniper] #2692025
08/27/19 06:16 PM
08/27/19 06:16 PM
BcudaChris Offline
BcudaChris  Offline
Over torqueing? Possibly a great many. AN fittings are all over the place on aircraft though, and once you've jacked one up, you usually don't do it again. You get the feel for it. The hangars I worked in usually had a set of line wrench crows feet for torqueing fittings, but just like a car, or even more so in a little airframe, you aint getting a torque wrench on a large percentage of the line fittings. A lot of (most even) times too, you're working with aluminum tubing (not on brakes) for hard lines, fuel, hydraulic, pito/static, even high pressure air on turbine aircraft. I would never put an un-lapped aluminum flared solid line on anything.
Basically, if you're an Ug-wrench, you won't last long working on aircraft. Most everything is aluminum and you'll only spend so much time fixing stripped and broken off stuff before the boss taps you on the shoulder and you're cleaning spark plugs and moving airplanes around.
Re: Brake flare kit recommendations [Re: BcudaChris] #2692041
08/27/19 07:26 PM
08/27/19 07:26 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Steel or Stainless steel, flats from finger tight is more than acceptable for assembling flared fittings.
Red
Re: Brake flare kit recommendations [Re: BIGGERED] #2692367
08/28/19 05:58 PM
08/28/19 05:58 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
The Eastwood tool worked great!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Brake flare kit recommendations [Re: BloFish] #2692503
08/29/19 07:45 AM
08/29/19 07:45 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Eastwood on car flaring tool is inexpensive and works great. I have hanging on the wall that tool and a 20 foot roll of break line and a package of fittings. I also have the Eastwood tight space ratcheting break line tubing cutter. Again- inexpensive and works wonderfully.
Keep old mopars alive.
Re: Brake flare kit recommendations [Re: 2boltmain] #2692561
08/29/19 10:33 AM
08/29/19 10:33 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I had purchased a traditional flaring set, which worked fine, but decided to try the Eastwood. I never looked back.
Re: Brake flare kit recommendations [Re: 71charger] #2692743
08/29/19 09:59 PM
08/29/19 09:59 PM
ky.
K
kenworth_goose Offline
K
ky.
I have a part # for the style we use. It's way better than the snap on we have. I've used several different ones and this is by far the best. Pistol Grip Hydraulic Flaring Tool Kit - Part# SRR PFT409
Re: Brake flare kit recommendations [Re: John_Kunkel] #2692765
08/30/19 12:17 AM
08/30/19 12:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Those look nice. I used the K-Tool international KTI70081, same as Eastwood Professional. It makes nice flares, but needs to be vice mounted. For a few bucks more the mastercool listed is much more portable.
I'll have to look at those lapping tools. I have two of the stainless brake lines that don't want to seal well, and there were the pre-made lines from Right Stuff. The lines I made sealed just fine.
