Re: Oil pickup for 7 inch deep pan
[Re: gss]
#2691793
08/27/19 01:46 AM
08/27/19 01:46 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Depending on what your working with it might be easier to just start with a new straight piece if tube, and weld the pickup screen part onto it. On my 400 to 500" stroker with BCR caps and girdle, I ended up making a pickup like mentioned above. I forgot what tube diameter and wall thickness I used? I think it may have just been 3/4" 0.065" or 0.083" wall DOM, which catches the threads further down the hole because the tube is a bit undersized. Really, a 7/8" wall tube would have been better, but the threaded end would need machined down a bit for the 1/2" NPT die.
If stock 3/8" NPT, a 5/8" tube should work.
FWIW, I calculated the inside area difference between a 5/8" 0.065" wall tube and a 3/4" 0.065" wall tube to see what change in area is when converting from 3/8" to 1/2" pickups. The 3/8 NPT, 5/8" OD tube, has 0.495" id, and a cross section area of 0.192442185 The 1/2 NPT, 3/4" OD tube, has 0.620" id, and a cross section area of 0.301907054 That is a 36.2578 % difference in cross section area. Not sure how the extra area of the larger pickup tube would affect oil pump performance?
[Re: gss]
#2691803
08/27/19 03:05 AM
08/27/19 03:05 AM
Posts: 43,332 Bend,OR USA
Cab_Burge
The early (1965 to 1970) C body BB oil pick up may work if your willing to bend it forward to get the pick up screen nearer the bottom of the oil pan. I may have one in a stock Pioneer box with a part number on it, I'll check in the shop in the morning and post it on here if I do. Have you look at the Moroso and Milidon 3/8 pickups for their 7 inch deep center sump oil pans yet? If not maybe you should I use to have one of each but not anymore after twisting one of them off trying to get one more full turn into the block boss to make the pick up fit the pan better
