PPG 2210 Plum crazy! #2691316
08/25/19 06:32 PM
08/25/19 06:32 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
This question I’m sure has come up before but I’m getting ready to have a TA painted with PPG 2210 Is this the best match for the original single stage paint from the 70s. Here is a spray out but it’s hard to get a good photo. Any suggestions
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: PPG 2210 Plum crazy! [Re: 19cuda73] #2691498
08/26/19 10:18 AM
08/26/19 10:18 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Looks good to me.
2011 Drag Pak Challenger
Re: PPG 2210 Plum crazy! [Re: rickseeman] #2691558
08/26/19 12:33 PM
08/26/19 12:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by rickseeman
Looks good to me.
iagree
And will add there are a lot a variables that affect the final color when spraying metallic. The gun tip size, distance away from the panel, primer color, the painter themselves, number of coats applied and the list goes on. Do be aware that a single stage metallic cannot be wet sanded to remove any imperfections, orange peel etc. Once it's dry, it's what you have beer
Re: PPG 2210 Plum crazy! [Re: TJP] #2691800
08/27/19 02:27 AM
08/27/19 02:27 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Not too familiar with what paint is available now, but back in the day with the original RM brand purple we added clear to the last coats of paint so it could be buffed and it lasted way better. They also used this color on imperials with 1/2 the metalic, deep plum, that looked really nice, and did not fall off and fade as bad. I am sure there is a single stage clear that will work, and I would use it or go base clear. Color you have looks good, I doubt they have the exact metal flakes anymore. Ppg and RM were a little off from each other in the 80s, but there is no doubt what color you have there is mopars purple.
Re: PPG 2210 Plum crazy! [Re: 19cuda73] #2692058
08/27/19 08:13 PM
08/27/19 08:13 PM
The Naughty Spot
BirdinPieces Offline
The Naughty Spot
Call Mark at Magnum Auto Restorations in Lasalle, Illinois. He is painting my car PCP sometime this fall. He went to a PPG seminar awhile ago and he said they made a modern formula that was an exact match. It was compared to an original can someone at the factory found in a corner somewhere.
The Bird Some are wise, and some are otherwise... Say what you want, but in the end, it is what it is...
Re: PPG 2210 Plum crazy! [Re: BirdinPieces] #2692083
08/27/19 09:16 PM
08/27/19 09:16 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Very good advice here !!
