Valve lash adjustment 660 lift roller #2691018
08/24/19 08:08 PM
08/24/19 08:08 PM
IN. USA
Leinky Offline OP
Leinky  Offline OP
IN. USA
I have a 540 ci Mega iron block, with aluminum heads. Trying to find out what to set my valve clearance at. I have a 660 lift roller cam. Can anyone help?
Call Bill after 3:00 PM Eastern time. DO NOT REPLY BY E-MAIL 765-457-0132 Home or 765-437-8393 Cell Indiana
Re: Valve lash adjustment 660 lift roller [Re: Leinky] #2691067
08/24/19 10:56 PM
08/24/19 10:56 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I'd start with .026 on both intake and exhaust.
Re: Valve lash adjustment 660 lift roller [Re: Leinky] #2691078
08/24/19 11:52 PM
08/24/19 11:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
What brand and grind number?
Cranes where around .026 hot, Bullitts are .016 hot and others are all different on the lash like the Isky 660 roller being around .028 if my memory is accurate,
The original Racer Browns (pre 1980s)might have been .032 hot shruggy
Re: Valve lash adjustment 660 lift roller [Re: Cab_Burge] #2691763
08/26/19 11:35 PM
08/26/19 11:35 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
I have a 612 iron Mega block, B-1 aluminum heads, Crane 648 lift cam, I set both intake and exhaust at .18 cold,
I like a bit tighter lash on all my roller engines, never had any issues, good luck
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
