Re: Who's prepping for Drag Week 2019?
[Re: ksj]
#2687661
08/14/19 12:14 PM
08/14/19 12:14 PM
Posts: 2,837 Connecticut
FurryStump
Connecticut
I am, 68 barracuda fastback, 410ci. I just need to swap center sections from 4.10 to 3.73 the week before. Then just pack stuff to haul. Probably run the valves the week before. Fixed an annoying slow trans leak. Found a bad rear wheel bearing swapped that out. Not much really. Goal is to run quicker than 11.99 in the heat.
[Re: ksj]
#2687663
08/14/19 12:15 PM
08/14/19 12:15 PM
fast68plymouth
So. Burlington, Vt.
Dragweek........ def already missing the blow-by-blow reports..........delivered as only MoparBilly could.
[Re: Dragula]
#2689282
08/19/19 07:25 AM
08/19/19 07:25 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
My Dad and I are not going this year, we decided it was too far away and while the tracks were awesome we didn't think that area and traffic would be a good time for a couple of Okies. I have been real lazy in getting my car going this year, but right on schedule with Drag Week I got it running, had a leak, then found a cracked converter snout. So it kind of feels like drag week prep lol. The difference this time is I put a empty trans case in it, dropped it off the jacks, threw the cover on and pushed it into the corner.
Really going to miss Billy's recap this year. His recap was awesome even if you were at the event!
68 Barracuda Formula S 340
[Re: NoFrills]
#2690738
08/23/19 08:38 PM
08/23/19 08:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I barely passed high school so dont expect a big right up from me. I did spend most of the day putting wipers back in my car. So that means it will not rain the whole time. Dont say that.. I was trunk monkey for my buddy in his 52 Ford PU truck.. he has the stock vacumn wipers on it with I think were the original blades.. and we pulled out of Milan Detroit headed to Pennsylvania we hit a bad rain storm(was a tornado about 10 miles ahead of use).. we finally made it but we played hell most of the say... the next year we had new wipers and blades
[Re: MR_P_BODY]
#2690802
08/23/19 10:55 PM
08/23/19 10:55 PM
Bad340fish
Tulsa OK
My Wipers were the MVP last year for sure! That and my air cleaner cover from the baking aisle lol
