904 tranny issue #2690380
08/22/19 03:49 PM
08/22/19 03:49 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
I have a late model 360 magnum with a 904 tranny in my 33 Plymouth. Both engine and tranny are stock. When taking off the tranny shifts from low into 2nd nice and smooth like it's supposed to. It will not shift into high unless you feather the gas pedal. It will always shift into high, but you must feather(or goose) the gas pedal. Any suggestions on why ??
Re: 904 tranny issue [Re: 2abodymcodes] #2690383
08/22/19 04:00 PM
08/22/19 04:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have a kickdown linkage hooked up?
Re: 904 tranny issue [Re: 2abodymcodes] #2690385
08/22/19 04:03 PM
08/22/19 04:03 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Two possibilities.
1) The front clutch seals are leaking. How is Reverse?
2) Governor sealing rings are worn. Once it's in 3rd does it ever drop out?
Re: 904 tranny issue [Re: John_Kunkel] #2690386
08/22/19 04:10 PM
08/22/19 04:10 PM
Shelby, Ohio
2
Shelby, Ohio
kick down is hooked up. Reverse is fine, does not drop out of gear
Re: 904 tranny issue [Re: 2abodymcodes] #2702282
09/30/19 02:26 PM
09/30/19 02:26 PM
Shelby, Ohio
2
Shelby, Ohio
My kickdown was not adjusted correctly (too tight). After some adjustments, it shifts fine now.
