Re: How Hot Do TailPipes Get?
[Re: 340SIX]
#2690286
08/22/19 10:43 AM
08/22/19 10:43 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've measured the exhaust tips on my C55 at 150+ degrees after some "enthusiastic" driving.
[Re: stumpy]
#2690288
08/22/19 10:45 AM
08/22/19 10:45 AM
Posts: 15,376 Omaha Ne
TJP
Omaha Ne
Too many variables to answer that other than a wild ass guess. Depends on the engine, the tune up, the length of the exhaust system the size of the exhaust, type of muffler, thickness of the pipes etc. I've seen systems that were to hot to touch and some that were almost cool. Uhh you left out, single or dual, number of cylinders, crossover pipe or not, at what ambient temp., at what RPM, LOL
[Re: 360view]
#2690521
08/23/19 02:20 AM
08/23/19 02:20 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Conditions?
Whenever water is not dripping out the tailpipe and no “fog” seen then it is above 212 degrees F.
Full throttle for more than 60 seconds on a hot summer day while overtop blacktop pavement? 1000 F at the exhaust manifold declining to 500 F at muffler outlet to 350 F at tip. If the tailpipes are extra large diameter like 4 inches lower above numbers. If stainless steel raise above numbers.
I vote for this as the best answer. On a directly related point, I would add that as the temperature falls going toward the rear exit, so does the pressure. As the temperature and pressure decrease, so does any benefit decrease when trying to improve the exhaust system. Likewise, decreasing the pipe diameter slightly near the tip causes no measurable loss of power, which the factory did with some exhaust tips.
[Re: feets]
#2691823
08/27/19 07:30 AM
08/27/19 07:30 AM
Posts: 858 Southeast Pa.
SALEM1912
Southeast Pa.
I've measured the exhaust tips on my C55 at 150+ degrees after some "enthusiastic" driving. "enthusiastic" driving. But officer I need to know how hot my tailpipes are getting! I am going to save that line. LOL
[Re: 340SIX]
#2691879
08/27/19 10:33 AM
08/27/19 10:33 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Ok, thanks. Wanted to shoot some 500-degree paint on just the tailpipes. As was putting SS X in the middle.with SS Muffs Just hated to see the tailpipes go to crap look wise This was done 7 yrs ago,a lot hotter than the tailpipes,from the outlet back,still looks like it did when painted.
