Re: Bulldog 426 Hemi Block
[Re: iapco103]
#2689985
08/21/19 11:25 AM
08/21/19 11:25 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Cool!
Any information about order details/history and delivery time?
Rich H.
Esse Quam Videri
[Re: iapco103]
#2690007
08/21/19 12:46 PM
08/21/19 12:46 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
That's a good schedule even w/ the delay! Glad it worked out! I saw on facebook where a guy in KY just got 2 hemi blocks from them that were ordered earlier this year. Looks promising!
[Re: iapco103]
#2690031
08/21/19 02:28 PM
08/21/19 02:28 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Ordered at the beginning of March 2019 with a delivery date of 5/31/2019.
1st block was NFG because of a casting defect that did not show up until almost the end of machining. Back to square one. Was it in the Deck ? passenger side rear ?
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: iapco103]
#2690037
08/21/19 02:42 PM
08/21/19 02:42 PM
ZIPPY
S.E. Michigan
Paul,
That's actually not bad at all.
Just for info:
Did you purchase direct or did you go through a dealer?
thx
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2690041
08/21/19 03:06 PM
08/21/19 03:06 PM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
Paul,
Just for info:
thx I dealt direct with Bradshaw and he seems to be on the up & up. Paul
[Re: ZIPPY]
#2690278
08/22/19 10:23 AM
08/22/19 10:23 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Just checked out their site, and the price to me doesn't seem unreasonable for what you are getting.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: Ray408G3Hemi]
#2690305
08/22/19 11:25 AM
08/22/19 11:25 AM
iapco103
Conroe , Texas
[quote=iapco103]Ordered at the beginning of March 2019 with a delivery date of 5/31/2019.
1st block was NFG because of a casting defect that did not show up until almost the end of machining. Back to square one. Was it in the Deck ? passenger side rear ? [/quote The defect was in the area of where the mechanical fuel pump mounts, since this is going to be an absolute stock engine it was mandatory to have all of that intact. I would assume that someone using an electric fuel pump got an early Christmas present. Paul
[Re: iapco103]
#2690425
08/22/19 06:48 PM
08/22/19 06:48 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
HI, good for you that you got it. What is the weight of it and the bore size?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2690428
08/22/19 06:54 PM
08/22/19 06:54 PM
iapco103
Conroe , Texas
HI, good for you that you got it. What is the weight of it and the bore size? Shipping weight was 350 lbs, so I am thinking about 305-310 lbs. Bore size is roughed at 4.240, will finish at 4.250. Paul
[Re: iapco103]
#2690944
08/24/19 02:59 PM
08/24/19 02:59 PM
Hemi_Joel
Minnesota
HI, good for you that you got it. What is the weight of it and the bore size? Shipping weight was 350 lbs, so I am thinking about 305-310 lbs. Bore size is roughed at 4.240, will finish at 4.250. Paul That's not too bad. Can that same block be bored to 4.500, or is that a different casting?
[Re: Hemi_Joel]
#2690963
08/24/19 03:59 PM
08/24/19 03:59 PM
iapco103
Conroe , Texas
HI, good for you that you got it. What is the weight of it and the bore size? Shipping weight was 350 lbs, so I am thinking about 305-310 lbs. Bore size is roughed at 4.240, will finish at 4.250. Paul That's not too bad. Can that same block be bored to 4.500, or is that a different casting? Pretty sure it is the same casting for 4.5 , massively thick Siamese cylinder walls. Paul
[Re: iapco103]
#2691126
08/25/19 08:22 AM
08/25/19 08:22 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Glad your block came in! I almost ordered one from him but got gun shy after seeing all of the bad press on him over the years. Ended up buying a mega block from Matt Hensley instead. I was just at Nickens brothers last week. Looks like they are still busy, and had some very high end builds going on. Keep us updated as I may still buy one of the bulldog blocks as a spare. -Dave Picture of my new 426 Gen II Hemi Block , now its off to Nickens Brothers for finish machine work. Paul
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: ZIPPY]
#2692333
08/28/19 02:58 PM
08/28/19 02:58 PM
ZIPPY
S.E. Michigan
Hmm. Well, the picture links do work for me.
Good luck to those who are chasing this.
I hope Bulldog can keep it together, as almost everything out of the Chrysler camp seems to be bad news lately.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2701489
09/27/19 05:44 PM
09/27/19 05:44 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
One of the local builders I do heads for is going to be putting together a Hemi street motor. 526”, and it’s going to be built around the Bulldog block.
It was ordered roughly 8 weeks ago, and was delivered this week. It hasn’t gotten scrutinized very hard yet, but nothing obviously “wrong” with it has been discovered to this point.
Pump gas, hyd roller, the MP/Ede heads. I’m not sure what the plan is for induction.
[Re: fast68plymouth]
#2719568
11/26/19 09:08 PM
11/26/19 09:08 PM
iapco103
Conroe , Texas
Got my block back from Nickens Brothers a couple of weeks ago, Just got to work on it a few days ago. So far , so good. Molnar crank & rods KB pistons Mopar restoration cam & lifters
I have everything else to finish it , will post as I go
Subaru engine commandeered the engine stand , so that's why its on the pallet , LOL. Paul
