How Hot Do TailPipes Get? #2690085
08/21/19 05:31 PM
08/21/19 05:31 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
The tailpipes them self, not the head pipes
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2690089
08/21/19 05:42 PM
08/21/19 05:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Too many variables to answer that other than a wild ass guess. grin Depends on the engine, the tune up, the length of the exhaust system the size of the exhaust, type of muffler, thickness of the pipes etc. I've seen systems that were to hot to touch and some that were almost cool.
Re: How Hot Do TailPipes Get? [Re: stumpy] #2690155
08/21/19 09:43 PM
08/21/19 09:43 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Up here where the weather gets cold in the winter, and hot in the summer, I would have to say the time of the year will have an impact on how hot a tail pipe gets as well.
I've not ever seen a cold tailpipe on anything that has been running for more then 5 minutes, but I've used the tail pipes as a hand warmer in the winter a few times. Gene
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2690209
08/22/19 01:09 AM
08/22/19 01:09 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Hot enough to burn off condensation
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2690286
08/22/19 10:43 AM
08/22/19 10:43 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've measured the exhaust tips on my C55 at 150+ degrees after some "enthusiastic" driving.
- Stu Harmon
Re: How Hot Do TailPipes Get? [Re: stumpy] #2690288
08/22/19 10:45 AM
08/22/19 10:45 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree Uhh you left out, single or dual, number of cylinders, crossover pipe or not, at what ambient temp., at what RPM, LOL beer
Re: How Hot Do TailPipes Get? [Re: TJP] #2690295
08/22/19 10:50 AM
08/22/19 10:50 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Hot enough to melt a plastic bumper cover if the tail pipe is too close.
Re: How Hot Do TailPipes Get? [Re: burdar] #2690326
08/22/19 12:43 PM
08/22/19 12:43 PM
340SIX Offline OP
340SIX  Offline OP
Kinda was wondering if 500* or less something of that nature
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2690337
08/22/19 01:02 PM
08/22/19 01:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think that is way to high an estimate. I just checked my cat converters with a heat gun and they were at 195* tail pipes at 120*. The engine is a 5.7 hemi.
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2690366
08/22/19 02:23 PM
08/22/19 02:23 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Conditions?
Whenever water is not dripping out the tailpipe and no “fog” seen then it is above 212 degrees F.
Full throttle for more than 60 seconds on a hot summer day while overtop blacktop pavement?
1000 F at the exhaust manifold declining to 500 F at muffler outlet to 350 F at tip.
If the tailpipes are extra large diameter like 4 inches lower above numbers.
If stainless steel raise above numbers.
Re: How Hot Do TailPipes Get? [Re: 360view] #2690521
08/23/19 02:20 AM
08/23/19 02:20 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted by 360view
Conditions?
I vote for this as the best answer.
On a directly related point, I would add that as the temperature falls going toward the rear exit, so does the pressure. As the temperature and pressure decrease, so does any benefit decrease when trying to improve the exhaust system. Likewise, decreasing the pipe diameter slightly near the tip causes no measurable loss of power, which the factory did with some exhaust tips.
Re: How Hot Do TailPipes Get? [Re: kentj340] #2690551
08/23/19 08:40 AM
08/23/19 08:40 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Back before exhaust systems were made of stainless the tail pipe was the first thing to rot out, primarily because it was the last to heat up and first to cool off and condensation collected there first.
Re: How Hot Do TailPipes Get? [Re: Sniper] #2691649
08/26/19 05:04 PM
08/26/19 05:04 PM
340SIX Offline OP
340SIX  Offline OP
Ok, thanks. Wanted to shoot some 500-degree paint on just the tailpipes.
As was putting SS X in the middle.with SS Muffs
Just hated to see the tailpipes go to crap look wise
Re: How Hot Do TailPipes Get? [Re: feets] #2691823
08/27/19 07:30 AM
08/27/19 07:30 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
"enthusiastic" driving. But officer I need to know how hot my tailpipes are getting! I am going to save that line. LOL
Re: How Hot Do TailPipes Get? [Re: 340SIX] #2691879
08/27/19 10:33 AM
08/27/19 10:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This was done 7 yrs ago,a lot hotter than the tailpipes,from the outlet back,still looks like it did when painted.
Re: How Hot Do TailPipes Get? [Re: 62maxwgn] #2691959
08/27/19 02:14 PM
08/27/19 02:14 PM
340SIX Offline OP
340SIX  Offline OP
I blasted the Manifolds and used that same paint with a top coat of clear both with 1200*
But have some 500 High Heat made by then that has a gloss to it so was going to use it up on the tailpipes.
