Re: Bulldog 426 Hemi Block
[Re: BradH]
#2719764
11/27/19 02:54 PM
11/27/19 02:54 PM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
What was Nickens' verdict on the block? Did they need to fix any issues with it as it came from Bulldog? Keith said it was F'ing heavy, LOL. No real serious issues, going together rather smoothly. Paul
[Re: parksr5]
#2719771
11/27/19 03:12 PM
11/27/19 03:12 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Not too bad a price. But bargains don't last long on marketplace , so if someone needs this , they might want to move quickly.
[Re: iapco103]
#2769328
04/28/20 11:48 PM
04/28/20 11:48 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Congrats and glad you found that problem early enough. That looks so awesome!!!!
[Re: iapco103]
#2769381
04/29/20 08:55 AM
04/29/20 08:55 AM
Posts: 17,918 S.E. Michigan
ZIPPY
S.E. Michigan
Looks fantastic. I'm sorry to hear of the trouble with it. What all happened there?
Rich H.
Esse Quam Videri
[Re: DUSTER_340]
#2769409
04/29/20 10:48 AM
04/29/20 10:48 AM
iapco103
Conroe , Texas
Care to share what the oil blockage problem was? There was about 2 fluid oz's of iron swarf stuck in the main lifter galleys. Problem was revealed on a pre-oil check, no oil to the rocker arms. Whoever was running the gun drill must not have had the oil pressure turned up high enough. Not an excuse, just my theory. I can't believe I was so stupid to miss that. I could have sworn that I shone a flashlight down each passage, apparently NOT. oh well, all is good now. Paul
[Re: iapco103]
#2769530
04/29/20 03:21 PM
04/29/20 03:21 PM
Posts: 43,321 Bend,OR USA
Cab_Burge
Steel bristle bore brushes are your friend Never ASSUME anything on engine assembly ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I make sure and use them in every oil passage with cleaning solvent first and then air and again with either brake cleaner or carb cleaner, which ever one I have the most of in stock at that time and more air to insure no debris or any other gunk left in them ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
