Re: dead dakota.........still
[Re: rhad]
#2693297
08/31/19 11:06 PM
08/31/19 11:06 PM
Posts: 954 garnett kansas
rhad
garnett kansas
i pulled out the CPS today i got from my local chrysler dealer 3 days ago,it tested bad!!,what the H is goin on ???,i did not test it before install,guess i should have?looked around and found one i had replaced a year or so ago,it tested ok,put it in went for a drive,everything ok!!,i also looked over the wiring at the back on the drivers side,some of the injector wires had some cracking in them,so i applied some liquid tape (ever hear of that?)i also changed the ecm back to a used one i had,im getting really gun shy about getting more than a block away from the shop!!!
my ladder of success is missing some rungs
Re: dead dakota
[Re: rhad]
#2693330
09/01/19 01:57 AM
09/01/19 01:57 AM
Posts: 762 Ca
76440
Ca
,2 of the wires hook to the auto shutdown relay and the fuel pump relay, Did you change this auto shutdown relay or swap it with another relay?
Re: dead dakota
[Re: 76440]
#2693547
09/01/19 11:04 PM
09/01/19 11:04 PM
rhad
garnett kansas
ive changed relays at least twice!,drove fine today with the old CPS,im wondering if mopar had a bad batch of them?,they are from south of texas!!
Re: dead dakota
[Re: rhad]
#2694155
09/03/19 10:31 PM
09/03/19 10:31 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Hoping you had found something. Going to look at a '94 in the morning that has an "electrical" problem. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: dead dakota
[Re: I_bleed_MOPAR]
#2695398
09/08/19 10:16 AM
09/08/19 10:16 AM
rhad
garnett kansas
i really thought it was fixed!!,started and ran good for a couple of days,then died this morning,i havent installed the newest cps yet,its time for someone else to look at this thing!!! if the system is overcharging will that cause the CPS to go bad-burnout,etc???????????
Re: dead dakota
[Re: 360view]
#2696360
09/10/19 11:22 PM
09/10/19 11:22 PM
rhad
garnett kansas
i put in a new mopar CPS today and took the truck to a shop thats said to be good at fixing things,checked the old CPS and sure enough it showed bad after 3 days???????,he said it might be 2 weeks,just about has to be a shorted wire or a corroded connection somewhere
Re: dead dakota
[Re: poorboy]
#2696753
09/11/19 11:17 PM
09/11/19 11:17 PM
rhad
garnett kansas
i talked to a long time mopar tech today,he suggested that the CPS might be touching the flexplate/flywheel causing a transfer of fine metal shavings causing a short?,also said to double check the dist under the cam sensor to see if the wheel on the main shaft was tight,and a slight possibility that the flexplate was cracked?,tho he said it would make a BIG racket,which its not!,so i might have to shim the CPS just a little bit ????
Re: dead dakota
[Re: rhad]
#2697018
09/12/19 09:27 PM
09/12/19 09:27 PM
Posts: 2,046 ky.
kenworth_goose
ky.
i talked to a long time mopar tech today,he suggested that the CPS might be touching the flexplate/flywheel causing a transfer of fine metal shavings causing a short?,also said to double check the dist under the cam sensor to see if the wheel on the main shaft was tight,and a slight possibility that the flexplate was cracked?,tho he said it would make a BIG racket,which its not!,so i might have to shim the CPS just a little bit ???? I've never had to shim one of them. There is plenty of room to pull it up a little bit.
Re: dead dakota
[Re: kenworth_goose]
#2697031
09/12/19 10:27 PM
09/12/19 10:27 PM
rhad
garnett kansas
no adjustment on a 92 3.9,it just bolts to the back of the block with 2 bolts, look it up on rockauto for a picture,i made a 30 thou shim today out of some alum flashing,time will tell
Re: dead dakota
[Re: rhad]
#2701263
09/26/19 10:31 PM
09/26/19 10:31 PM
rhad
garnett kansas
I TOOK IT TO A SHOP WITH A YOUNG SMART GUY,HE SAID HE DROVE IT 15 MILES AND IT DIED,AND HE COULDNT TALK TO the computer??,so it must not be the cps??,he still has it!! sorry for the caps!
Re: dead dakota
[Re: rhad]
#2701336
09/27/19 09:29 AM
09/27/19 09:29 AM
I_bleed_MOPAR
Buford, GA
How can he "talk" to the PCM with OBD1? All the scan tool can do is read the code(s) on OBD1, right? No data stream or other info available? Tim
Re: dead dakota
[Re: I_bleed_MOPAR]
#2701410
09/27/19 01:33 PM
09/27/19 01:33 PM
Posts: 2,046 ky.
kenworth_goose
ky.
How can he "talk" to the PCM with OBD1? All the scan tool can do is read the code(s) on OBD1, right? No data stream or other info available? Tim Nope. You are limited as to what you can see but there will be some data available with obd1
Re: dead dakota
[Re: I_bleed_MOPAR]
#2701591
09/27/19 11:32 PM
09/27/19 11:32 PM
rhad
garnett kansas
i m,ay have used the wrong wording,he said something like he couldn't get anything from the ecm,i dont remember the exact phrase,it just seems like if the ecm shows dead there must be a bad connection,corroded wire,or something overheated?,after it sets for a few minutes it will start and drive,it never shows a check engine light??
Re: dead dakota
[Re: rhad]
#2705727
10/10/19 10:27 PM
10/10/19 10:27 PM
rhad
garnett kansas
went to get it today,guy said he found a loose correded connector in the ecm plug,i drove it about 10 miles and it died!,waited a couple minutes and it restarted like always,took it back to him for more work?,after all this i dont now think its the crank sensor,the ones i took out tested ok when not testing them on a metal top bench!!!!
