1978;truck fuel sending unit screw heads #2689512
08/19/19 06:13 PM
08/19/19 06:13 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Rounded off.Tried a drill screw extractor called grabbit.no go.Any ideas.
Re: 1978;truck fuel sending unit screw heads [Re: chargers777] #2689544
08/19/19 07:39 PM
08/19/19 07:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drill the screw heads off with a drill large enough the take the heads off without drilling in the threaded part of the screw. Remove the sending unit and there should be enough screw to get small vise grips on.
Re: 1978;truck fuel sending unit screw heads [Re: stumpy] #2689648
08/20/19 07:35 AM
08/20/19 07:35 AM
Perkiomenville PA
RWG75 Offline
RWG75  Offline
Perkiomenville PA
Take a dremel to the sides of the screw heads and make two flat surfaces across from each other. Grab the screw by those flats with a small vise grip. If all else fails, grind the screw heads completely away, remove the sender, grind the screw stubs flush then reclock the new sender and drill new holes. There's a metal ring cast in the plastic around the sender opening.
75 Charger SE - 440/4, cop suspension
76 Daytona - survivor
76 Daytona - tweaked
77 PW - macho clone, sno-commander, frankenram
79 RC - this was your fathers 4x4
79 LRE - More fun than it looks
Re: 1978;truck fuel sending unit screw heads [Re: RWG75] #2689690
08/20/19 09:59 AM
08/20/19 09:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I wouldn't recommend using a Dremel around a gas tank because of sparks. But if you are super careful it might be ok.
Anyone use any of the tire softeners?
by DaveRS23. 02/23/20 06:27 PM
Phasing rotor with MSD Crank Trigger
by Sammy. 02/23/20 06:09 PM
78 Lil Red Express red interior questions
by demon. 02/23/20 05:57 PM
Small elect. moter question
by 5carguy. 02/23/20 05:33 PM
Moparts Recent Posts
340's Rule, 360's Drool !!
by MR_P_BODY. 02/23/20 06:27 PM
Engine and Trans Lost & Found
by Alaskan_TA. 02/23/20 06:18 PM
by T2R9. 02/23/20 06:14 PM
