Beehives with solid roller? #268927
03/27/09 10:40 PM
03/27/09 10:40 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
Has anyone tried beehives with a solid roller? I'm going to be using a XR280R Comp on my 418 sb (242 248 dur. 570 576 lift). Comp recommends 914 Springs that are 165 @ 1.800 and 385 @ 1.200. I was thinking of trying the 26120 beehives that measure 155 @ 1.880 and 377 1.280. I realize that comp only recommends these springs for solid flat tappets and hydraulic rollers, but the cam isn't that aggressive, is it?
The car is 80% street.
Any thoughts?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Beehives with solid roller? [Re: Fishmarket] #268928
03/27/09 10:51 PM
03/27/09 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a solid roller those pressures sound WAY light
that Comp told you... that sounds like flat tappet
numbers
Re: Beehives with solid roller? [Re: MR_P_BODY] #268929
03/27/09 10:59 PM
03/27/09 10:59 PM
Essex, Ont., Canada
Essex, Ont., Canada
Its an extreme energy mechanical roller and 914s are the recommended springs. Its a street roller not race, thats why I'm thinking I could try the beehives.
Part # 914-16
O.D. of Outer Spring 1.489
I.D. of Outer Spring 1.105
I.D. of Inner Spring .819
Damper No
Seat Load 165 @ 1.800
Open Load 385 @ 1.200
Coil Bind 1.110
Rate (Lbs./In.) 367
Re: Beehives with solid roller? [Re: Fishmarket] #268930
03/27/09 11:06 PM
03/27/09 11:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Comp states
"Will work with hydraulic or solid flat tappet cams as well as hydraulic rollers"
You'd think if there were any Solid Rollers they felt Beehives were suited for they would include solid roller in the print... They state there are applications that the Beehives just aren't suited for...
Re: Beehives with solid roller? [Re: 1_WILD_RT] #268931
03/27/09 11:22 PM
03/27/09 11:22 PM
Essex, Ont., Canada
Essex, Ont., Canada
Yes, exactly. That's why I'm asking if anyone has tried it, especially with a cam that isn't very aggressive like the xr280r.
Re: Beehives with solid roller? [Re: Fishmarket] #268932
03/28/09 09:49 AM
03/28/09 09:49 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
the beehive has LOWER pressures than the Comp RECOMMENDED spring , is it REALLY a choice ???
Re: Beehives with solid roller? [Re: JohnRR] #268933
03/28/09 10:04 AM
03/28/09 10:04 AM
Central Jersey
Mjollnir Offline
Mjollnir  Offline
Central Jersey
Beehive springs are inherently more efficient than traditional parallel-wound springs. Their tapered design means that the spring uses less energy controlling its own mass, leaving more capacity available to control valve motion even if its published spring rates are slightly lower than the recommended traditional spring.
Re: Beehives with solid roller? [Re: Mjollnir] #268934
03/28/09 11:03 AM
03/28/09 11:03 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Those springs sound way too light.I have the XR 280R in my my 470" street car(great cam!) I'm using Comp's 938 spring 200# at 1.900 and a tick over 500# open at 1.250. The 938's were the recommended spring.
Re: Beehives with solid roller? [Re: Fishmarket] #268935
03/28/09 11:28 AM
03/28/09 11:28 AM
AndyF Offline
AndyF  Offline
Beehives can work for solid roller cams. Just have to select the correct beehive. The 26120 has 370 lbs/inch while the 26055 has 400 lbs/inch spring rate. Either of those should work okay with a mild street roller cam, especially if you're using a 1.50 rocker arm and aren't planning on twisting it very hard.
If you look closely at the spring specs you'll see that if you shim the 26120 springs about 0.050 they'll match the 914 specs almost exactly. Zero difference and therefore they should work fine. You just have to watch out for coil bind since you'll be really close. You'll have to be careful about the shim stack to get enough seat pressure but not run into coil bind.
Re: Beehives with solid roller? [Re: JohnRR] #268936
03/28/09 11:53 AM
03/28/09 11:53 AM
Essex, Ont., Canada
Essex, Ont., Canada
Check out the installed heights there AhAh.
Re: Beehives with solid roller? [Re: Fishmarket] #268937
03/28/09 11:59 AM
03/28/09 11:59 AM
Essex, Ont., Canada
Essex, Ont., Canada
Here is the link to the Comp Cams web site for the cam card.
http://compcams.com/Cam_Specs/CamDetails.aspx?csid=688&sb=0
Now everyone can see that 914 is the recommended spring. The same spring is recommended in the Camquest software so I doubt it is a typo.
Thank you Andy F...I assume that you have actually tried using the springs on a solid roller combo? If so, do you think they would have a shorter sreet life than using the recommended double spring?
The car won't go over 6500rpm...
Re: Beehives with solid roller? [Re: Fishmarket] #268938
03/28/09 02:38 PM
03/28/09 02:38 PM
AndyF Offline
AndyF  Offline
The 26120 has the same spring rate as the 914 so they are interchangeable as long as you can get the correct seat load and not coil bind. You'll have to carefully check that on your heads though since the 26120 is designed for .590 lift and you're shooting for something really close to that.
Re: Beehives with solid roller? [Re: Fishmarket] #268939
03/28/09 04:54 PM
03/28/09 04:54 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Beehives are a gimmick, period.
They could have the best rate characteristics in the world, but because they have no damping, they resonate (surge). The higher the ramp rate of the cam, the more susceptible to surge/valve float they will be. A mechanical roller will cause this to happen at a lower rpm that a flat tappet would. A single or dual spring with a damper will attain a significantly higher RPM than a beehive would, rates being equal.
8.30's @3400 lbs
Re: Beehives with solid roller? [Re: Mike Swann] #268940
03/28/09 10:13 PM
03/28/09 10:13 PM
Essex, Ont., Canada
Essex, Ont., Canada
Hi Mike thanks for your opinion, however I think you should read this article from David Vizard regarding the many attributes of beehives. I'm not sure what real world testing you have done on the subject, but I can respect your perspective. I really don't have an exceptional amount of personal experiences with them myself, but I haven't read anything bad about them yet, except for the increased price over conventional springs... including this article from such an accomplished engine builder.
http://www.babcox.com/editorial/ar/eb50354.htm
Ex-aerospace engineer David Vizard, with over 3,500 published articles and 29 books (5 publisher’s best sellers) is one of the world’s most widely published automotive writers.
He is also a university lecturer, holds numerous patents and is a winning engine/car builder. In his best year he amassed a combined 169 track records, first places and championship wins, from just 8 engines. Technology he has developed has been used on everything from F1 across the board to drag race and dirt cars.
Re: Beehives with solid roller? [Re: Fishmarket] #268941
03/28/09 10:31 PM
03/28/09 10:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Unless comp has unleashed a cast roller cam for mopars,I'd forget the spring specs they list and put a good dual spring(PAC or Isky),225ish seat and 500ish open.
Re: Beehives with solid roller? [Re: Fishmarket] #268942
03/28/09 10:39 PM
03/28/09 10:39 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Cool, and it seems he is a shill for Comp now.
Personal experience is I tried an identical looking spring that was manufactured by Isky with aluminum retainers in the 70's on a SBC. It floated at 5800 RPM. I replaced the springs with Chevy performance springs single and a damper and got 6500 rpm.
The weight analysis and the smoke about variable spring rate is alluring but doesn't change the fact that it is an undamped system.
Its seems you have made up your mind anyhow, so let me know how you make out.
And by the way, I have a BSME and own a service company that does vibration analysis on stationary gas turbines and wellhead gas compressors. I stand by my comments above.
8.30's @3400 lbs
Re: Beehives with solid roller? [Re: Mike Swann] #268943
03/29/09 12:08 AM
03/29/09 12:08 AM
Essex, Ont., Canada
Essex, Ont., Canada
Thanks Mike, but I believe the identical looking spring from the '70s that isky sold did not have ovate wire and also had common coil spacing. Two advancements that play very well into the control of frequency related vibrations. I have a friend that works in high performance for PAC , testing their springs. Having talked with him about the pros of the new beehives, I am willing to give it a try. I also believe that PAC is supplying Comp with their springs, but you may be right...Vizard may be a shill for PAC as well.
Re: Beehives with solid roller? [Re: Mike Swann] #268944
03/29/09 11:20 AM
03/29/09 11:20 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I believe we have a WINNER ...
Re: Beehives with solid roller? [Re: Fishmarket] #268945
03/29/09 12:56 PM
03/29/09 12:56 PM
The beehive springs where designed ot fit a certain application in the market, SB Fords and Chevy so they wouldn't have to have thier heads cut for bigger diameter springs. I'm a firm beleiver in the old adage, if it ain't broke don't fix it. Good springs are availbe for the motor you have so why by a adapter spring Theory is great, proven performance is way better
Re: Beehives with solid roller? [Re: Fishmarket] #268946
03/29/09 02:19 PM
03/29/09 02:19 PM
SoCal
Brian Hafliger Offline
SoCal
Mock up your valvetrain first, with checking springs. Set a dial indicator up on the intake and exhaust retainers and check your ACTUAL lift at the valve.
Now subtract your lash, and you have your ACTUAL lift at the valve (without deflection, but don't worry about it).
Now set those beehive springs up so that when installed, at max lift you'll be .070 from coil bind on each one.
Don't worry about the pressure at closed. Just set them so that at max lift you'll have .070 till coil bind.
And after all that....you'll gain nothing over a good 1.570 roller spring. And if that spring fatigues, your lifters will come apart!
And they will fatigue....
Brian
Brian Hafliger
