Re: Wrong plugs means rebuild time
[Re: hemi-itis]
#2688594
08/16/19 10:47 PM
08/16/19 10:47 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I cant understand how someone even try putting the long plugs in there. I would think the pistons would hit the plugs but they are probably down the hole pretty far. Well at least shouldn't be that expensive to repair . Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2688596
08/16/19 10:57 PM
08/16/19 10:57 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
“Some” of the spark plugs were too long.
I guess you just use what you have laying around.
[Re: AndyF]
#2689315
08/19/19 09:51 AM
08/19/19 09:51 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
When I first got my 68 Charger, 318, it ran kind of funny. I found it had short reach, accel plugs in it like a person would use in a big block with iron heads. Of course no harm done, but seems like a weird error to make. Maybe somebody thought it would go faster with 440 spark plugs
Rich H.
Esse Quam Videri
