long wheel studs for disc brakes #2688537
08/16/19 08:10 PM
08/16/19 08:10 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
i cant seem to find the correct long wheel stud for a 71 b body disc brake hub/rotor. i ordered a moroso set but the knurl does not go through the rotor far enough to engage the hub. i have long studs in another 71 but as i recall the hub and rotor was all 1 piece ( i could be wrong ) . i see arp sels a stud that looks like it may work but its listed for early ford disc brakes . the part number for that is 100-7707.
Re: long wheel studs for disc brakes [Re: Runner] #2688562
08/16/19 09:17 PM
08/16/19 09:17 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I went through that on my Duster. IIRC, I found a set from Mr. Gasket that had a smaller knurl.
Re: long wheel studs for disc brakes [Re: slantzilla] #2688568
08/16/19 09:39 PM
08/16/19 09:39 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
The knurl diameter is correct, it just needs to be another 1 inch or so out so that it would acually engage the hub
