Re: 77 Cordoba back brakes hyper sensitive
[Re: SportF]
#2688335
08/16/19 09:34 AM
08/16/19 09:34 AM
RWG75
RWG75
Clean and grease the contact points between the shoes and the backing plate. Best tell tale sign is if they grab hard first few times then settle down. With out the grease they get a little stuck and when you apply enough pressure to unstick them it's enough to lock them up.
[Re: chargers777]
#2688492
08/16/19 05:33 PM
08/16/19 05:33 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
They are locking up in gravel after barely touching the brake pedal.Adjusters are backed off.Any ideas? Why are the adjusters backed off? When you put the drums on, there should be some drag. If the shoes are pulled away from the drum because the adjuster is backed off, the lockup is happening because the slack is being taken up suddenly. (I can picture it better than explain it). Have the shoes ever been correctly adjusted?
John
[Re: chargers777]
#2688922
08/17/19 10:46 PM
08/17/19 10:46 PM
RapidRobert
for sure post what it ends up being.
[Re: chargers777]
#2688926
08/17/19 11:08 PM
08/17/19 11:08 PM
SattyNoCar
Thanks everyone.Brake shoes are on right.no leaks.new master cylinder.lines are hooked up correctly. You didn't answer my questions.
John
[Re: chargers777]
#2689820
08/20/19 07:27 PM
08/20/19 07:27 PM
Posts: 6,306 nowhere
Sniper
nowhere
Drums don't heat up with driving they do if the shoes are dragging
