77 Cordoba back brakes hyper sensitive #2688171
08/15/19 06:55 PM
08/15/19 06:55 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
They are locking up in gravel after barely touching the brake pedal.Adjusters are backed off.Any ideas?
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2688204
08/15/19 08:09 PM
08/15/19 08:09 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Check the orientation of the brake shoes per wheel;
Both brake-shoes have different sized/length brake-lining.
The shoes with the shortest lining should be mounted towards the front of the car.
The ones with the long lining towards the rear.
Also,
file or grind some bevels on the leading edges of the brake shoes if they don't have that.
This prevents 'grabbing' of the brake-shoes.
Re: 77 Cordoba back brakes hyper sensitive [Re: BigBlockMopar] #2688207
08/15/19 08:23 PM
08/15/19 08:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Brakes are like a mullet short in front and long in back.
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2688303
08/16/19 07:56 AM
08/16/19 07:56 AM
Minn
SportF Offline
SportF  Offline
Minn
Is this after the car sits awhile? If so it is "somewhat" normal. If there has been a master cylinder change somewhere along the line you may have a master with a 1" or less bore which is a manual set up. Best of luck to you.
Re: 77 Cordoba back brakes hyper sensitive [Re: SportF] #2688335
08/16/19 09:34 AM
08/16/19 09:34 AM
RWG75
RWG75
Clean and grease the contact points between the shoes and the backing plate. Best tell tale sign is if they grab hard first few times then settle down. With out the grease they get a little stuck and when you apply enough pressure to unstick them it's enough to lock them up.
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2688492
08/16/19 05:33 PM
08/16/19 05:33 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Why are the adjusters backed off?
When you put the drums on, there should be some drag. If the shoes are pulled away from the drum because the adjuster is backed off, the lockup is happening because the slack is being taken up suddenly. (I can picture it better than explain it).
Have the shoes ever been correctly adjusted?
John
Re: 77 Cordoba back brakes hyper sensitive [Re: SattyNoCar] #2688600
08/16/19 11:12 PM
08/16/19 11:12 PM
Maryland
MoparMike1974 Offline
Maryland
Sounds like maybe a leaking axle seal.
Re: 77 Cordoba back brakes hyper sensitive [Re: MoparMike1974] #2688635
08/17/19 07:39 AM
08/17/19 07:39 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
or a wheel cylinder
perception is 90% of reality
Re: 77 Cordoba back brakes hyper sensitive [Re: Mr T2U] #2688773
08/17/19 03:35 PM
08/17/19 03:35 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
back in the 80s I had a 76 Charger and a 75 Cordoba. Dad had a 78 Monaco wagon. seems like all of the "late-B" bodies were all like this. My current 78 Sport Fury is the same way. Nature of the beast. I remember seeing a tsb somewhere about this, where they said to put smaller wheel cylinders on them for the issue.
All the others I mention had had their rear brake shoes replaced during our ownership. My 78 still has its original everything on the back. (only 54k miles)
I also remember in my work, seeing a tsb (yeah I know, not a Mopar) about Rangers, Aeroflop vans from the late 80s/early 90s and I don't remember the complaint (besides being Fords) but the tsb said to replace the shoes and they gave a pn for the updated shoes..... IDK what you have on tehre for brake shoes, but unless you have some OLD stock on there, its hard telling what the composition of the brake linings you have may be.....
Re: 77 Cordoba back brakes hyper sensitive [Re: volaredon] #2688815
08/17/19 05:47 PM
08/17/19 05:47 PM
Nashport, OH
Nashport, OH
Thanks everyone.Brake shoes are on right.no leaks.new master cylinder.lines are hooked up correctly.
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2688922
08/17/19 10:46 PM
08/17/19 10:46 PM
for sure post what it ends up being.
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2688926
08/17/19 11:08 PM
08/17/19 11:08 PM
SattyNoCar Offline
SattyNoCar  Offline
You didn't answer my questions.
John
Re: 77 Cordoba back brakes hyper sensitive [Re: SattyNoCar] #2688947
08/18/19 01:15 AM
08/18/19 01:15 AM
Nashport, OH
Nashport, OH
Yes.They are adjusted to a slight drag when removing brake drum.I backed the adjusters off to try it.No change.
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2689164
08/18/19 07:27 PM
08/18/19 07:27 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
if the emergency brake is on just a tad they will do that
Re: 77 Cordoba back brakes hyper sensitive [Re: 500ciDuster] #2689724
08/20/19 12:50 PM
08/20/19 12:50 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Watching.
I've had probably 2 dozen Magnums and a few Dobas, NEVER had that issue. I"ve had master cyl's go bad and not release the brakes till I loosened the line at the MC
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 77 Cordoba back brakes hyper sensitive [Re: Magnumguy] #2689756
08/20/19 03:27 PM
08/20/19 03:27 PM
Warminster, Pa.
Slant69 Offline
Slant69  Offline
Warminster, Pa.
Could possibly be the rubber hose going to the rear brake lines internally collapsing, therefore not allowing the hydraulic pressure to release. I had this happen on a Dodge Durango. If you drove long enough the rear brakes would drag on the drums and heat up.
Re: 77 Cordoba back brakes hyper sensitive [Re: Slant69] #2689817
08/20/19 07:17 PM
08/20/19 07:17 PM
Nashport, OH
Nashport, OH
Drums don't heat up with driving
Re: 77 Cordoba back brakes hyper sensitive [Re: chargers777] #2689820
08/20/19 07:27 PM
08/20/19 07:27 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
they do if the shoes are dragging
Re: 77 Cordoba back brakes hyper sensitive [Re: Sniper] #2689842
08/20/19 08:27 PM
08/20/19 08:27 PM
Nashport, OH
Nashport, OH
Shoes aren't dragging.Drove it 2 hrs home.Brakes are hyper sensitive in gravel and lock up.fine on pavement with no pulling or smell as if it were hot
