Codes from Grand daughters Jeep Patriot #2688172
08/15/19 06:55 PM
08/15/19 06:55 PM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
My grand daughter is have problems with her 2007 Jeep Patriot , it seems to chop the steering wheel
when she turns and the throttle response , from a stop seems to be lagging. Here is a pic of the codes..
Frank
Re: Codes from Grand daughters Jeep Patriot [Re: duster2] #2688561
08/16/19 09:16 PM
08/16/19 09:16 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
CVT transmission . Check the fluid level (special fluid) also what do you mean "seems to chop the steering wheel" ?
Re: Codes from Grand daughters Jeep Patriot [Re: SALEM1912] #2688704
08/17/19 11:44 AM
08/17/19 11:44 AM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
Like the Jeep is locked in and the front end I'd chopping or hopping.
Inside and outside tire not traveling at same speed, but trying to...
Frank
Re: Codes from Grand daughters Jeep Patriot [Re: duster2] #2689889
08/21/19 12:06 AM
08/21/19 12:06 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
4WD?
Re: Codes from Grand daughters Jeep Patriot [Re: SALEM1912] #2690010
08/21/19 12:59 PM
08/21/19 12:59 PM
Midwestern Indiana
duster2 Offline OP
duster2  Offline OP
Midwestern Indiana
Yes its a 4 x 4.
Re: Codes from Grand daughters Jeep Patriot [Re: duster2] #2691409
08/25/19 11:23 PM
08/25/19 11:23 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Do the codes come right back? Is it any different in 4wd? How many miles, even with a trans problem I don't why you would have the frt jerking like you explain. Wondering if you stuck in 4wd. But that wouldn't explain the trans codes.
