Re: Help! Did my MSD digital 7 die? [Re: RThunder] #2689543
08/19/19 08:38 PM
08/19/19 08:38 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I had a 7530 that died at the track. ran fine and shut the car off. When I went to start it had no spark. I had to replace it with the 7530T since the first one was obsolete. I now run the Grid and also keep a spare one in the trailer. You just don't know what sets them off.
Re: Help! Did my MSD digital 7 die? [Re: Deepockets] #2689551
08/19/19 09:12 PM
08/19/19 09:12 PM
gregsdart Offline OP
Mine did the same. It ran great then nothing.
Re: Help! Did my MSD digital 7 die? [Re: fast68plymouth] #2693933
09/03/19 12:01 PM
09/03/19 12:01 PM
PA
Harry's Taxi 2 Offline
PA
I was able to try out the new 150# seat-440# open springs this weekend and that was the problem with the 6600 rpm limit......it went to 7100 without a hiccup.
Now as for being any faster, it didn't seem to add much to the power level yet. I can at least test shift points now and the fuel curve, while needing some tweaking, is now making sense too.
It did equal my best previous e.t of 9.12 in 60* 1800 D.A. weather a few months ago. It was 80* 2200 D.A. on Saturday's test session.
Thanks (fast68plymouth) for the spring pressure advise .
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Help! Did my MSD digital 7 die? [Re: Harry's Taxi 2] #2694022
09/03/19 04:56 PM
09/03/19 04:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I was pretty sure it needed more spring.
Glad that worked out for you.
Re: Help! Did my MSD digital 7 die? [Re: fast68plymouth] #2694324
09/04/19 12:27 PM
09/04/19 12:27 PM
PA
PA
I'm actually more disappointed that I didn't think to look into spring pressures more and question Mike Jones about it. I've been very pleased with his cams....I guess he just made a mistake as any of us could have.
I looked (in hindsight) at pretty much every catalog cam of similar size (and smaller w/.842 lobes) and they all recommend over 400# of open pressure.
