Rebuild with Leaky Main Seal #2687508
08/14/19 02:09 AM
08/14/19 02:09 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Hey engine gurus. I had my engine rebuilt and it sat for three years before I installed it and broke it in. It has a bad rear main seal leak. Is it common for this to happen and will it eventually swell up and stop leaking as oil lubricates it or has it dried out due to inactivity and need to be replaced?
I’m listening.
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2687668
08/14/19 12:20 PM
08/14/19 12:20 PM
You need to determine exactly where the oil is leaking out of, the main seal itself or the side seals or maybe even somewhere else work scope
If it is leaking out of the seal between the crankshaft and the seal it will be slung out away from the crankshaft flange on the engine side of the flex plate or the flywheel scope
If it is not slung out on those then it is leaking from somewhere else work
If that is the case you may be able to fix it a little easier boogie
Check it out and let us know what you see and find out wrench up
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2687677
08/14/19 12:30 PM
08/14/19 12:30 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
as with any seal, it will not swell up on its own and stop leaking. if it sat for a bunch of years and then you started it, its not a big surprise that its leaking ultimately It was dry when you started it and either tore, or wore away, or it was installed wrong to begin with.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Rebuild with Leaky Main Seal [Re: Jerry] #2687720
08/14/19 01:59 PM
08/14/19 01:59 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
iagree
Re: Rebuild with Leaky Main Seal [Re: Cab_Burge] #2687767
08/14/19 06:10 PM
08/14/19 06:10 PM
Spokane Valley, WA
Spokane Valley, WA
Good info. It's an A-727 car ands I can tell you that with the inspection plate off, motor oil is slinging all over the underside of my headers, more on the passenger side. With the plate on, it runs out the drainage hole. It's definitely not coming from the pan and it's not all over the torque converter. I had the pan off last week and the lower end of the main seal where it meets the pan looks well sealed but it's hard to see anything else.
I thought rear main seals were made of rope. shruggy They rip?
Is this enough info or do I need to get the car up in the air and run her until she gushes?
I’m listening.
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2687774
08/14/19 06:30 PM
08/14/19 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should get it up in the air and clean it real good with brake cleaner.. while its in the air have someone
run it so you can find the leak.. if its leaking that bad it wont take long.. if needed clean it a few times
wave
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2687848
08/14/19 09:53 PM
08/14/19 09:53 PM
All the OEM Mopar V8 up to or maybe even a little later than 1985 had rope seals, they are not included in over haul gasket sets since around 1992 or so. They where replaced with a rubber like seal back then and the original paper type side seals went away around 10 yrs ago also whiney
On your deal make sure you know exactly where the oil is leaking from before starting to fix it, don't be surprised if it has multiple leaks like from both of the side seals or one side seal and the oil pan gasket around one oil pan bolt hole or even a rear oil galley plug leaking or the cam rear cam plug leaking scope
I've had all of them leak in different motors in the past, not so much anymore with better seals and using a good adhesive sealant to completely seal up the sides of the rear main seal holder to the blocks up Keeps in the loop on your progress, you can fix this wrench up
Re: Rebuild with Leaky Main Seal [Re: Cab_Burge] #2687902
08/15/19 04:26 AM
08/15/19 04:26 AM
Spokane Valley, WA
Spokane Valley, WA
Thanks, guys. It’s absolutely not the pan. I fixed that one. smile I’ll get her nose in the air this weekend and see what I can find. I dread the thought of having to pull the transmission to fix something like the cam plug seal.
I’m listening.
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2687923
08/15/19 08:14 AM
08/15/19 08:14 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's probably a long shot, but check the oil sending unit for leaks before getting too deep into rear seals. 2¢
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Rebuild with Leaky Main Seal [Re: 3hundred] #2688609
08/16/19 11:40 PM
08/16/19 11:40 PM
Spokane Valley, WA
Spokane Valley, WA
Robert
Great idea, Robert. I'm going to clean it up and go over it with a fine tooth comb. Question. Will brake clean eat the paint off my trans or engine?
I’m listening.
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2688616
08/17/19 12:00 AM
08/17/19 12:00 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Brake Clean could be iffy, test a place first.
Carb Cleaner is harsher, in my experience.
I usually use Simple Green, or Wax & Grease Remover on a rag, follow up with a dry rag.
Least invasive is glass cleaner or kitchen-use "surface cleaner", but they might smear as much as clean...
I once had a Diplomat that poured oil out of its oil pressure sender, hope you're "lucky" that way.
I have a BB with a similar but less-leakage symptom to yours, so I'm curious what you find.
Re: Rebuild with Leaky Main Seal [Re: Big Bad Bee] #2688617
08/17/19 12:04 AM
08/17/19 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Robert
If you have decent paint on the engine break clean wont hurt the paint.. also if you start on the
top of the engine and work downward it tends to work better(less mess)but look at everything on the
top and work downward
wave
