New brakes.... bleeding? #2687844
08/14/19 09:37 PM
08/14/19 09:37 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
New lines /everything Bench bled master cylinder before installing. How would you proceed?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: New brakes.... bleeding? [Re: JMCFAN] #2687896
08/15/19 01:22 AM
08/15/19 01:22 AM
None
71rm23 Offline
71rm23  Offline
None
Start right rear, left rear, right front, left front and use a helper or brake bleeder. Just nake sure M/C is full and not to bring in more air
Re: New brakes.... bleeding? [Re: 71rm23] #2688372
08/16/19 11:08 AM
08/16/19 11:08 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: New brakes.... bleeding? [Re: BloFish] #2688374
08/16/19 11:22 AM
08/16/19 11:22 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Open all the bleeders and let gravity do most of the work. I put a length of hose on all bleeders to route the fluid into containers. In under 10 minutes, I had fluid at all four wheels. Keep an eye on the master cylinder level.
Re: New brakes.... bleeding? [Re: burdar] #2688402
08/16/19 01:03 PM
08/16/19 01:03 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I tried that at the right rear wheel overnight.... nothing. But a few slow presses on the pedal and I had fluid..
Went and bought a hand vacuum bleeder.... Saturday project
