Re: stainless exhaust band clamps ?
[Re: moparx]
#2687627
08/14/19 10:44 AM
08/14/19 10:44 AM
Posts: 22,715 Bitopia
jcc
Bitopia
My first experience with SS band clamps was decades ago on my trucks. I really like them, I haven't used a u bolt clamp in years. I've used numerous brands, never found any noticeable differences.
[Re: moparx]
#2687635
08/14/19 11:20 AM
08/14/19 11:20 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I used the ones from Summitt. They may have been Pypes brand. But I liked them real well.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: poorboy]
#2687984
08/15/19 11:18 AM
08/15/19 11:18 AM
Posts: 19,589 north of coder
moparx
that's kind of interesting to hear about the turning issue. my tailpipes have a flat tab welded to them that is used as a hanger, so i shouldn't have to worry about them turning. thanks for the suggestions guys !
[Re: poorboy]
#2687991
08/15/19 11:32 AM
08/15/19 11:32 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I use them on my cars too. I also put a small spot weld on the tube and muffler to stop them from moving. A quick hit with an angle grinder is all it takes to separate them when needed.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 67_Satellite]
#2688273
08/16/19 12:38 AM
08/16/19 12:38 AM
Posts: 141 Pennsylvania
polaris400cc
Pennsylvania
I like your short bolt thought thats a good idea. I have only installed them with 100% silicone caulking inside the band then tighten them down. Have not installed a single u bolt style clamp since the first time I used a stainless band clamp
[Re: moparx]
#2688274
08/16/19 12:47 AM
08/16/19 12:47 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
The original ones (the benchmarks) are made right here in Auburn Hills, MI. - Torca. They make the TorcTite, the EasySeal, the AccuSeal, & the DuraSeal. I brought the AccuSeals & DuraSeals into the mainstream aftermarket in the early 2000's before anybody had them. Nobody else carries the DuraSeals - they have always been OE only & they are the strongest lap-joint band clamp in the world. Here's my page on the clamps, *including the 2.5" butt-joint clamp the Torca Coupler: http://www.classicchambered.com/classic/AccuSeal.html The only other size the coupler is available is 3.5". I do not carry the thinwall TorcTites or EasySeals.
