Re: To machine or not
[Re: Garry Owen]
#2686914
08/12/19 02:44 PM
08/12/19 02:44 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Don't think of it as pitting, it's "oil reservoirs". If you're not looking for maximum performance, run it.
[Re: John_Kunkel]
#2686916
08/12/19 03:00 PM
08/12/19 03:00 PM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
That pit looks suspicious to me. I would be pressure testing that block. The cylinder wear indicates water. Not that I don't advocate using a good short block on the cheap.
[Re: rickseeman]
#2686936
08/12/19 04:16 PM
08/12/19 04:16 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I know guys that would run that without even thinking about it. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
[Re: Garry Owen]
#2686961
08/12/19 05:37 PM
08/12/19 05:37 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I've seen the same thing on one of my old M.W. stocker motors that was store inside my shop in the dry Mojave desert, never sat outside at night unless it was at a race on one of my old car hauler trucks. Condensation sneaks into the cylinders with the exhaust valves open, especially as it cools down over night after being run and warmed up or hot ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: bobby66]
#2687098
08/12/19 11:19 PM
08/12/19 11:19 PM
Garry Owen
Some go, and some blow. Only one way to find out. True.
[Re: Magnum]
#2688679
08/17/19 10:12 AM
08/17/19 10:12 AM
Posts: 10,764 North Dakota
6PakBee
North Dakota
If you are on a budget build I am assuming you aren't trying to squeeze every last HP out of it. If you find no other problems with the pistons/rods, the real question is, "how much taper do you have?". If you have minimum taper (<0.005") I'd break the glaze, rering it and run it.
