360 to 440 swap in Trailduster - parts #2687260
08/13/19 01:42 PM
08/13/19 01:42 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Can anyone help me out with what I would need to swap a 440 into my 74 Trailduster? It is in stock original condition currently with a 360 auto.
I have a 440 and a big block 727 out of a 68 Plymouth wagon.
Advice on what I would need to make it happen?.
Any leads on parts/parts sources would be appreciated.
Re: 360 to 440 swap in Trailduster - parts [Re: 70mopes] #2687266
08/13/19 01:53 PM
08/13/19 01:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Water-pump, motor mounts, oil pan and pick-up, exhaust manifolds, linkages for a start.
I have mechanical Aptitude.
I can screw up anything.
Re: 360 to 440 swap in Trailduster - parts [Re: bboogieart] #2687423
08/13/19 08:24 PM
08/13/19 08:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the Trailduster is a 4x4, you will need to swap the output shaft from your small block 727 into the big block 727.
I believe you also need to add some extra length to a few wires to reach stuff on the big block. Gene
Re: 360 to 440 swap in Trailduster - parts [Re: poorboy] #2687625
08/14/19 10:39 AM
08/14/19 10:39 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
2wd or 4wd? Make a difference on the mounts.
Saw your want ad. Your asking for 75 and up mounts so I'm guessing 4wd?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 360 to 440 swap in Trailduster - parts [Re: moparmarks] #2687723
08/14/19 02:17 PM
08/14/19 02:17 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Yes it is a 4x4. It is a 74 Trailduster too. Seems that it would have specific motor mounts for a 4x4 for that year.
Re: 360 to 440 swap in Trailduster - parts [Re: 70mopes] #2687757
08/14/19 05:36 PM
08/14/19 05:36 PM
moparmarks Offline
moparmarks  Offline
The mounts all revolve around weather it has a married or divorce transfer case.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 360 to 440 swap in Trailduster - parts [Re: moparmarks] #2687811
08/14/19 07:41 PM
08/14/19 07:41 PM
moparmarks Offline
moparmarks  Offline
Ok so you have a 74 but your wanting the 75 and up mounts? Is your transfer case married or divorced? 74 should be divorced.
I probably have mounts, water pump housing and the oil pan. Just need to know which mounts you need.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 360 to 440 swap in Trailduster - parts [Re: moparmarks] #2687840
08/14/19 09:26 PM
08/14/19 09:26 PM
WV
Danny Offline
Danny  Offline
WV
im no expert, but i dont think the trailduster or ramcharger ever had divorced transfer case, even first year production
Re: 360 to 440 swap in Trailduster - parts [Re: Danny] #2687858
08/14/19 10:23 PM
08/14/19 10:23 PM
Alberta
440_Offroader Offline
Alberta
Good point. Wonder if a 74 Ramcharger would have the 203 or 205 transfer case? Never paid attention to that as my focus is usually on the half doors on the 74s. BTW, you'll need the smaller diameter brake booster too.
Re: 360 to 440 swap in Trailduster - parts [Re: 440_Offroader] #2687869
08/14/19 11:11 PM
08/14/19 11:11 PM
moparmarks Offline
moparmarks  Offline
Ya I don't know about the Ranchargers. Have had a gazillion trunks and no Ranchargers.
You can use the larger booster with the BB. At lease I did.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 360 to 440 swap in Trailduster - parts [Re: moparmarks] #2688079
08/15/19 03:39 PM
08/15/19 03:39 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
The truck is bone stock 1974 Trailduster. It has the NP 203 full time drive setup with a column shift 727A tied to a 360. I asked about the '75 mounts because while researching this swap, I saw that those were brought up on a couple threads....
