Re: 360 to 440 swap in Trailduster - parts
[Re: 70mopes]
#2687266
08/13/19 01:53 PM
08/13/19 01:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Water-pump, motor mounts, oil pan and pick-up, exhaust manifolds, linkages for a start.
I have mechanical Aptitude. I can screw up anything.
[Re: moparmarks]
#2687723
08/14/19 02:17 PM
08/14/19 02:17 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
Yes it is a 4x4. It is a 74 Trailduster too. Seems that it would have specific motor mounts for a 4x4 for that year.
[Re: moparmarks]
#2687811
08/14/19 07:41 PM
08/14/19 07:41 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Ok so you have a 74 but your wanting the 75 and up mounts? Is your transfer case married or divorced? 74 should be divorced. I probably have mounts, water pump housing and the oil pan. Just need to know which mounts you need.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2688079
08/15/19 03:39 PM
08/15/19 03:39 PM
70mopes
Maple Valley, WA
The truck is bone stock 1974 Trailduster. It has the NP 203 full time drive setup with a column shift 727A tied to a 360. I asked about the '75 mounts because while researching this swap, I saw that those were brought up on a couple threads....
