'68 Dart Disc Brake LH studs source or pn? #2687027
08/12/19 08:13 PM
08/12/19 08:13 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I found one of the front studs butchered on my Dart and would like a proper LH thread replacement. Does anyone offer these and if not can anybody help me with a p/n for a driver side disc brake stud?
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Jeremiah] #2687067
08/12/19 09:24 PM
08/12/19 09:24 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a few dozen left hand 7/16" thread studs new in boxes, take a picture of the one you have and the bottom of it if possible. I have several different sizes and kinds.
JB Rhinehart, Realist
A-Body's RULE!
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Rhinodart] #2687868
08/14/19 11:11 PM
08/14/19 11:11 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Okay here are my measurement pics. Looks like the replacement was Dorman 610-131 which is now obsolete.
Here are my pics:
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Jeremiah] #2687872
08/14/19 11:13 PM
08/14/19 11:13 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
And here is the height measured from the rotor to the tip of the stud (essentially the length of the threaded portion).
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Jeremiah] #2688243
08/15/19 09:57 PM
08/15/19 09:57 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here are the studs I found new in the box. They are slightly different but pretty much the same. I have not measured them yet but they appear to be what you need. One has H131 cast into the base and the other has KH M probably meaning Kelsey Hayes, they are both 7/16" left hand studs.
A-Body's RULE!
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Rhinodart] #2689744
08/20/19 01:54 PM
08/20/19 01:54 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Jim,
The studs on my car are very close to the "KH" studs you have. If you will part with two of them shoot me a PM.
Thank you for the support!
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Jeremiah] #2689745
08/20/19 01:56 PM
08/20/19 01:56 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Also, what is the hot ticket for a set of rotors? I'd like to get something anodized if possible to avoid rusty vents.
Re: '68 Dart Disc Brake LH studs source or pn? [Re: Jeremiah] #2689768
08/20/19 04:46 PM
08/20/19 04:46 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Can't anodize steel/iron.
Re: '68 Dart Disc Brake LH studs source or pn? [Re: John Brown] #2689783
08/20/19 05:59 PM
08/20/19 05:59 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Then let's go with this:
"DEEP" zinc silver plating
From rotorpros.net
For some reason I was thinking of the anodized rotor hat on one of the race cars?
