Head bolts
#2686790
08/12/19 10:09 AM
08/12/19 10:09 AM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
How many times would you use a set of head bolts? Would it strictly be based on # times torqued down? Can you factor how little run time on the engine before removing the heads?
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
Re: Head bolts
[Re: 426runner]
#2686844
08/12/19 11:45 AM
08/12/19 11:45 AM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From ARP:
Are ARP bolts and studs re-usable?
Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement.
