8 3/4? #2686039
08/09/19 01:29 PM
08/09/19 01:29 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
what is the proper position for the gear ratio tag and sure grip lube tag?
Re: 8 3/4? [Re: PLMCRZY] #2686077
08/09/19 04:06 PM
08/09/19 04:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You should have 2 areas where the pumpkin is surfaced larger than the nuts, one about 10:00 and one about 3:00.
SG tag goes at 10 - above the fill plug.
Ratio tag goes at 3.
Re: 8 3/4? [Re: topside] #2686078
08/09/19 04:18 PM
08/09/19 04:18 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
thanks!
